ilogic : How to fill the notch only upwards in the bending direction in the flat
tkddud711
tkddud711
Hi?
I am using ilogic in sheet metal parts as below.
How to fill the notch only upwards in the bending direction in the flat pattern?
Sub Main()
	'Prevents Inventor from crashing.
	InventorVb.DocumentUpdate()
	'Check if open document is sheetmetal
	Dim oDoc As Document = ThisApplication.ActiveDocument
	If oDoc.DocumentSubType.DocumentSubTypeID <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Exit Sub
	Else
	'MsgBox("Is sheetmetal")
	'Check if open sheetmetal document has flatpattern view
	Dim oSMD As SheetMetalComponentDefinition
	oSMD = oDoc.ComponentDefinition
	If Not oSMD.HasFlatPattern Then Exit Sub
	Dim oFlat As FlatPattern = oSMD.FlatPattern
	'MsgBox("Has flatpattern")
	'Check for bend features
	Try
		Dim BendCount As Integer = oSMD.Bends.Count
		If BendCount < 1 Then Exit Sub
		'MsgBox("# bends " & BendCount)
	Catch
		MsgBox("error: Sheetmetalcomponentdefinition.Bends.Count (Can't find bends?)")
		Exit Sub
	End Try
	Try
		Dim oBendCount As Integer = oFlat.FlatBendResults.Count
		'MsgBox("# oBends " & oBendCount)
		If oBendCount < 1 Then Exit Sub
	Catch
		MsgBox("error: FlatBendResults.Count (Can't find bends?)")
		Exit Sub
	End Try
	'Check if feature "BendMarkerHoles" exists
	Dim FeatureName As String = "BendMarkerHoles"
	Try
		Dim oFTS As FlatPatternFeatures = oFlat.Features
		If oFTS.Count > 0 Then
			For Each oFT As PartFeature In oFTS
				If oFT.Name <> FeatureName Then Continue For
				Try
					oFT.Delete()
				Catch
				End Try
				Exit For
			Next
	Catch
		MsgBox("error in MAIN()")
	End Try
	BendMarker(oFlat)
End Sub
Sub BendMarker(oFlat As FlatPattern)
	Dim oEdges As Edges
	Dim oHoleCenters As Object = ThisApplication.TransientObjects.CreateObjectCollection
	Dim oSketch As PlanarSketch
	'Flatpattern sketch -------------------------------------------------------------------------
	Try
		oSketch = oFlat.Sketches.Add(oFlat.TopFace, True)
	Catch
		oSketch = oFlat.Sketches.Add(oFlat.BottomFace, True)
	End Try
	oSketch.Edit()
	'Detect bend down ---------------------------------------------------------------------------
	Try
		oEdges = oFlat.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True)
		WorkEdges(oHoleCenters, oSketch, oEdges)
	Catch
		MsgBox("error: GetEdgesOfType 64005/kBendDownFlatPatternEdge")
	End Try
	'Detect bend up -----------------------------------------------------------------------------
	Try
		oEdges = oFlat.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True)
	Catch
		MsgBox("error: GetEdgesOfType 64004/kBendUpFlatPatternEdge")
	End Try
	Call oFlat.Features.HoleFeatures.AddDrilledByThroughAllExtent(oHoleCenters, 0.05, kPositiveExtentDirection)
	Try
		Dim oHoleFeat As HoleFeature = oFlat.Features.HoleFeatures.Item(1)
		oHoleFeat.Name = "BendMarkerHoles"
		oSketch.ExitEdit()
		oSketch.Name = "MarkedBends"
	Catch
		MsgBox("error: GetEdgesOfType kBendUpFlatPatternEdge (64004) en/of kBendDownFlatPatternEdge (64005) kunnen niet worden gevonden")
	End Try
End Sub
Sub WorkEdges(ByRef oHoleCenters As Object, ByRef oSketch As PlanarSketch, oEdges As Edges)
	'Create list of coördinates
	Dim oDoc As Document = ThisDoc.Document
	Dim oLoft As Integer = 0
	For Each HFeature As LoftedFlangeFeature In oSMD.Features.LoftedFlangeFeatures
		oLoft = 1
	Next
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim Xi As Integer = 0
	BendCount *= 4
	Dim oPointGrid(BendCount, 1) As Double
	For Each oEdge As Edge In oEdges
		Try
			Dim oEnt As SketchEntity = oSketch.AddByProjectingEntity(oEdge)
			oPointGrid(Xi, 0) = oEnt.StartSketchPoint.Geometry.X.ToString
			oPointGrid(Xi, 1) = oEnt.StartSketchPoint.Geometry.Y.ToString
			Xi = Xi + 1
			oPointGrid(Xi, 0) = oEnt.EndSketchPoint.Geometry.X.ToString
			oPointGrid(Xi, 1) = oEnt.EndSketchPoint.Geometry.Y.ToString
			Xi = Xi + 1
			oEnt.Delete	'Deleting projected geometry
		Catch
			'MsgBox("error")
		End Try
	Next
	If Xi = 0 Then Exit Sub
	'Loft Filter Start
	If oLoft = 0 Then GoTo Endloft
	'MsgBox("Loft Code")
	Dim intCount1, intCount2 As Integer
	Dim DictX As Object = CreateObject("Scripting.Dictionary")
	Dim DictY As Object = CreateObject("Scripting.Dictionary")
	'Filter Points within certain promximity of each other
	For intCount1 = 0 To Xi
		For intCount2 = 0 To Xi
			If intCount1 <> intCount2 Then
				'																		2D-array
				'																		 |_0__|_1__|
				'																		0|_X__|_Y__|	0,0 = x coördinate 0,1 = y coördinate
				'																		1|_X__|_Y__|	1,0 = x coördinate 1,1 = y coördinate
				'																		2|_X__|_Y__|	2,0 = x coördinate 2,1 = y coördinate
				'											X-Value intCount1		  X-Value intCount2									Y-Value intCount1	   	  Y-Value intCount2
				'						Compare			2D Array Cel X,0	With	  2D Array Cel X,0			And		Compare			2D Array Cel X,1	With	  2D Array Cel X,1
				If EqualWithinTolerance(oPointGrid(intCount1, 0), oPointGrid(intCount2, 0), 0.1) And EqualWithinTolerance(oPointGrid(intCount1, 1), oPointGrid(intCount2, 1), 0.1) Then
					Try
						DictX.Add(oPointGrid(intCount2, 0) & " " & oPointGrid(intCount2, 1), oPointGrid(intCount2, 0))
						DictY.Add(oPointGrid(intCount2, 0) & " " & oPointGrid(intCount2, 1), oPointGrid(intCount2, 1))
					Catch
						'Nothing
					End Try
		Next intCount2
	Next intCount1
	'MsgBox("IntCount " & intCount1 & " " & intCount2)
	'Filter points.
	'Only the points which are not close to each other remain.
	Dim i As Integer = 0
	Dim oPointGridFilteredX As Object = CreateObject("Scripting.Dictionary")
	Dim oPointGridFilteredY As Object = CreateObject("Scripting.Dictionary")
	For i = 0 To Xi
		If Not Xi = 0 Then
			If Not DictX.Exists(oPointGrid(i, 0) & " " & oPointGrid(i, 1)) Then
				oPointGridFilteredX.Add(oPointGrid(i, 0) & " " & oPointGrid(i, 1), oPointGrid(i, 0))
				oPointGridFilteredY.Add(oPointGrid(i, 0) & " " & oPointGrid(i, 1), oPointGrid(i, 1))
			Else
				'Nothing
	Next
	'Convert the created dictionary of filtered points into an 2d-array
	Dim ArrayFiltered(oPointGridFilteredX.Count - 1, 1) As Double
	Dim ii As Integer = 1
	For ii = 0 To oPointGridFilteredX.Count - 1
		ArrayFiltered(ii, 0) = oPointGridFilteredX.Items()(ii)
		ArrayFiltered(ii, 1) = oPointGridFilteredY.Items()(ii)
	Next
	'Place holecenters
	Dim iii As Integer = 0
	For iii = 0 To ii - 1
		Dim oP = oSketch.SketchPoints.Add(oTG.CreatePoint2d(ArrayFiltered(iii, 0), ArrayFiltered(iii, 1)), True)
		'MsgBox("oP " & ArrayFiltered(iii, 0) & " " & ArrayFiltered(iii, 1))
		If Not (ArrayFiltered(iii, 0) = 0 And ArrayFiltered(iii, 1) = 0) Then
			oHoleCenters.Add(oP)
	Next
	'Loft Filter End
	'Place holecenters
	If oLoft = 1 Then Exit Sub
	Endloft :
	'MsgBox("Non Loft Code")
		Dim P As Point2d = oEnt.StartSketchPoint.Geometry
		Dim oSP As SketchPoint = oSketch.SketchPoints.Add(oTG.CreatePoint2d(P.X, P.Y), True)
		oHoleCenters.Add(oSP)
		P = oEnt.EndSketchPoint.Geometry
		Dim oEP As SketchPoint = oSketch.SketchPoints.Add(oTG.CreatePoint2d(P.X, P.Y), True)
		oHoleCenters.Add(oEP)
	Next
End Sub
chandra.shekar.g
Autodesk Support
Autodesk Support
@tkddud711 ,
To try the iLogic feasibility, please provide non confidential Inventor files(before notch and after notch) to check the feasibility?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
tkddud711
Upward banding can eliminate circles,
Or maybe you want to draw green lines by 10mm on each side.
It was written with inventor 2020 version.
chandra.shekar.g
Autodesk Support
Autodesk Support
@tkddud711,
It seems that both parts are same. Please specify the difference in parts.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
tkddud711
chandra.shekar.g
Autodesk Support
Autodesk Support
@tkddud711,
Is this same behavior when it created through UI or manual steps?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
tkddud711
It is ilogic operation before change and manual operation after change.
