Inventor API : How to find sketch fully constrained using VB.net
umesh.mhaskar
umesh.mhaskar
Hello Everyone,
                         While working with Inventor API sketches i am not geting right constrain status with below process:
                       e.g. 1)  create new part
                              2)  create sketch1 and give required dimentions for fully constrained. now sketch1 is fully constrained , Extrude sketch1.
                              3)  create sketch2 with reference sketch1 face and use fix constrain option for fully constrained. now sketch2 is fully constrained. Extrude Skecth 2
                              4)  create sketch3 with with reference sketch1 face  and give required dimentions for fully constrained. now sketch3 is fully constrained.
                               When we finding above sketches constraining status using vb.net & inventor API its gives result for constrain status as below:
                Sketch1 = kFullyConstrainedConstraintStatus
                Sketch2 = kUnknownConstraintStatus
                Sketch3 = kUnknownConstraintStatus
Problem: Sketch2 & Sketch3 is gives kUnknownConstraintStatus result insted of kFullyConstrainedConstraintStatus.
Then is any another option in APi to get extact constraining status.
Umesh
Maxim-CADman77
I'd like to up this pretty old thread.
Have just faced impossibility to get true ConstraintStatus for Sketch named "Slice" in "Upper - Front.ipt" (Component of the Stapler legacy sample available at https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/3gnm93P9sPAWE6vndk7fjq.html).
API of Autodesk Inventor 2024 (and 2023.2.1) returns 51716 (kUnknownConstraintStatus) while Inventor knows there 6 constraints needed if the sketch is opened for edit (so API should return kUnderConstrainedConstraintStatus).
PS:
Autodesk knows about this issue (https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/ConstraintStatus-f...but issue is still actual.
Please vote for Inventor-Idea Text Search within Option Names
Curtis_Waguespack
Maxim-CADman77
Thank you for sharing the link...
I believe marking that thread as solved was a mistake thus I prefer to keep discuss the issue here.
Some more related info:
Here is my simplest iLogic code to reproduce the issue on the sample .IPT I've mentioned in previous message:
Option Explicit On
Dim oPartDoc As PartDocument = ThisDoc.Document
Dim oPCD As ComponentDefinition = oPartDoc.ComponentDefinition
For Each oSk in oPCD.Sketches
	logger.info(oSk.Name & " - " & [Enum].GetName(GetType(ConstraintStatusEnum), oSk.ConstraintStatus))
Next
I would take this Issue for known-but-not-solved-yet-API-issue if Design Checker Add-In (with default settings) won't get things right.
From this picture you can see that Design Checker reports the "Slice" sketch "faulty" (UnderConstrained) while my iLogic code gets the Unknown ConstraintStatus value.
PS:
I kindly hope @MjDeck or @YuhanZhang will look at this and probably comment this somehow.
YuhanZhang
Hi @Maxim-CADman77
The sketch "Slice" in the legacy data is a derived sketch, so it should be in fully constrained status, but in UI it still indicates it needs dimensions, so I logged this as INVGEN-68532. You can provide the number to query its status.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
