[Inventor 2027.1] Dimension gap to centermark is not consistent
I'm noticing the gap between centermarks and dimension lines is random when adding BaselineDimensionSets or ChainDimensionSets. The problem also occurs just when using the UI too. Am I missing something?
var intents = app.TransientObjects.CreateObjectCollection();
// geometry intents are linked to the centermark object
var intent = sheet.CreateGeometryIntent(centermark);
intents.Add(intent);
var placement = app.TransientGeometry.CreatePoint2d(0.0, drawingView.Center.Y + drawingView.Height / 2.0 + 10.0);
sheet.DrawingDimensions.BaselineDimensionSets.Add(intents, placement, DimensionTypeEnum.kHorizontalDimensionType)
Can confirm the dimension set members are attached to the centermark geometry in all cases.
Not sure if it matters but the holes in this example are generated from a Sketch Driven Pattern.
