[Inventor 2027.1] Dimension gap to centermark is not consistent
JOfford_13
JOfford_13
I'm noticing the gap between centermarks and dimension lines is random when adding BaselineDimensionSets or ChainDimensionSets. The problem also occurs just when using the UI too. Am I missing something?
var intents = app.TransientObjects.CreateObjectCollection();
// geometry intents are linked to the centermark object
var
intent = sheet.CreateGeometryIntent(centermark);
intents.Add(intent);
var placement = app.TransientGeometry.CreatePoint2d(0.0, drawingView.Center.Y + drawingView.Height / 2.0 + 10.0);
sheet.DrawingDimensions.BaselineDimensionSets.Add(intents, placement, DimensionTypeEnum.kHorizontalDimensionType)
Can confirm the dimension set members are attached to the centermark geometry in all cases.
(view in My Videos)
Not sure if it matters but the holes in this example are generated from a Sketch Driven Pattern.
lauri_barnhart
Greetings, @JOfford_13.
Hope you are well. Following up to see if you still need assistance or if you found a solution. Any update would be greatly appreciated.
Lauri | Community Manager
JOfford_13
Hi @lauri_barnhart, haven't gotten any feedback. Seems like a non-API issue so haven't submitted a ticket to ADN.
