Inventor 2025 OleDB Issue FYI: OleDBConnection is not defined
xenocatalyst
xenocatalyst
We have just updated to Inventor 2025.1 from 2024 and have had a problem with using one of our iLogic rules.
The rule is used to read and write to a MS Access Database and we rely on it in our workflow.
This was the error we experienced.
I believe I have found a solution, previously I use the below addreference and imports code in the rule header, but now it seems incomplete.
AddReference "System.Data"
AddReference "System.Core"
AddReference "System.Xml"
Imports System.Data.OleDb
Imports System.Data
Imports System.Xml
Imports System.Collections
I have had to add another line to the header.
AddReference "inventorelectrical/system.data.OleDb" 'new reference line
Imports System.Data
Imports System.Xml
I don't know if this is specific to our particular installation or not.
I hope this helps someone
t.karipidis
That works THANK YOU!!
