Inventor 2023 : Update Part mass into a for each loop with iLogic.
vpeuvion
vpeuvion
Hello, I'm having an update issue when I try to vary a parameter by a step.
I'm trying to retrieve the part's masses by varying a parameter.
For example, I have a rectangular Sheet Metal part with a length of "Length." If I create a rule and add this code:
Length += 200
iLogicVb.UpdateWhenDone = True
MessageBox.Show(iProperties.Mass)
Each time I run the rule, the part changes visually and the mass changes.
However, if I insert this code into a for Each loop, it no longer works.
For Length = 200 To 1000 Step 200
Next
I tried:
ThisApplication.CommandManager.ControlDefinitions.Item("PartRebuildAllCmd").Execute
ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
But without success. I'm out of ideas.
Does anyone have any suggestions?
My goal is to get all the part's masses for each configuration.
Thanks.
Vincent.
WCrihfield
Try that last block of code like this instead:
For i As Integer = 200 To 1000 Step 200
	Length = i
	RuleParametersOutput()
	InventorVb.DocumentUpdate()
	MessageBox.Show(iProperties.Mass.ToString())
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
vpeuvion
Hello @WCrihfield .
I forgot about RuleParametersOutput().😉
Thank you very much.
