- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I'm having an update issue when I try to vary a parameter by a step.
I'm trying to retrieve the part's masses by varying a parameter.
For example, I have a rectangular Sheet Metal part with a length of "Length." If I create a rule and add this code:
Length += 200 iLogicVb.UpdateWhenDone = True MessageBox.Show(iProperties.Mass)
Each time I run the rule, the part changes visually and the mass changes.
However, if I insert this code into a for Each loop, it no longer works.
For Length = 200 To 1000 Step 200 iLogicVb.UpdateWhenDone = True MessageBox.Show(iProperties.Mass) Next
I tried:
ThisApplication.CommandManager.ControlDefinitions.Item("PartRebuildAllCmd").Execute
ThisApplication.CommandManager.ControlDefinitions.Item("AppUpdateMassPropertiesCmd").Execute
But without success. I'm out of ideas.
Does anyone have any suggestions?
My goal is to get all the part's masses for each configuration.
Thanks.
Vincent.
