Inventor 2023 crashes when iLogic saves a part with model states
martin_pedersen
martin_pedersen
Inventor crashes when saving IPT with model states and iLogic rule as below.
It crashes when triggered by Rules On Events: "After Save Document".
ThisDoc.Document.ComponentDefinition.ModelStates.MemberEditScope = MemberEditScopeEnum.kEditAllMembers
'do something
ThisDoc.Document.ComponentDefinition.ModelStates.MemberEditScope = MemberEditScopeEnum.kEditActiveMember
If ThisDoc.Document.Dirty Then
	ThisDoc.Save
End If
Attached is IPT with the rule, and event trigger trigger set.
When rule dirties the document it requires a 2nd save...
Is there a workaround?
regards
Martin
WCrihfield
Hi @martin_pedersen.  I am not 100% sure, but it looks to me like a rule like that, being triggered by the 'After Save Document' event in the Event Triggers dialog, could very likely be causing an endless loop situation, which leads to the crash.  Any rule that is triggered to run 'after' saving a document, should not then include code to save that document again, especially if that code includes actions that may be 'dirtying' the document every time it runs.  When changing the 'MemberEditScope' status, I believe that action alone is dirtying the document, even if nothing else happens in the rule.  Therefore it will attempt to save every time, which triggers the rule again, in an endless cycle.
Wesley Crihfield
(Not an Autodesk Employee)
