Inventor 2021 SDK Developer tools - not seeing all addins
mslosar
Advisor Advisor
mslosar
Just installed Inventor 2021 and ran the installs for the sdk's user tools and developer tools
In VS 2019, i get an addin option for c++, but i'm not seeing anything for VB or C#. Am i missing something?
mslosar
Figured it out.
Note to Autodesk, you may want to consider this...
Our company redirects the standard Documents folders and whatnot to a specified folder connected to a backup system.  Most applications pick up the new location and deposit there files there with no issues.
The SDK installer is apparently hardcoded to put the template files in %USERPROFILE%\Documents\Visual Studio 2019\Templates
That was the issue here. I went to my virtually empty normal documents folder and found the templates there and moved them over to the redirected location. You may want to update the installer to pick up on that in the future.
saifP9SUR
Thank you mslosar. I managed to make C# and VB.NET templates (Inventor 2024) show up in Visual Studio 2022 Community Edition.
I copied the two zip files from C:\Users\saif\Documents\Visual Studio 2022\Templates\ProjectTemplates and put them in the following folder. Then they showed up in VS.
C:\OneDrive\...\Documents\Visual Studio 2022\Templates\ProjectTemplates
