Inventor 2020 Event Watcher: "OnDocumentChange" event not working
DRoam
Mentor Mentor
DRoam
For some reason, the "OnDocumentChange" event watcher is not working. From what I can tell from debugging, it's because the "OnDocumentChange" event is not being heard at all by the Event Watcher, while other ApplicationEvents are.
Can someone check and see if they see the same issue in 2020?
Any idea how to fix this issue?
DRoam
Update:
Looks like I'm getting the following message in the Output window with each document change:
Exception thrown: 'System.ArgumentException' in mscorlib.dll
It shows up twice, so I assume it's being thrown once with the "before" event and once with the "after" event.
Did a search for this error and didn't find much. Hopefully it's a useful clue for someone smarter than me.....
JelteDeJong
did you see this post? could be the same problem.
https://forums.autodesk.com/t5/inventor-customization/ondocumentchange-event-not-firing/m-p/4485795/...
Jelte de Jong
Blog: hjalte.nl - github.com
