Message 1 of 1
INVENTOR 2020 CRASHES ON REORDERING NODES
Hi All,
So I have VBA code to demote the occurrences into sub assembly.
When I run the code, INVENTOR crashes.
Any ideas on this issue?
Sub Demote_into_Assembly()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oSelset As SelectSet
Set oSelset = oAsmDoc.SelectSet
If oSelset.Count = 0 Then Exit Sub
Dim selectAsm As ComponentOccurrence
Set selectAsm = ThisApplication.CommandManager.Pick _
(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select the Assembly to demote the occurrence into [ESC:Cancel]")
If selectAsm Is Nothing Then Exit Sub
Dim oPane As BrowserPane
Set oPane = oAsmDoc.BrowserPanes.Item("Model")
Dim oSubAssyNode As BrowserNode
Set oSubAssyNode = oPane.GetBrowserNodeFromObject(selectAsm)
Dim oTargetNode As BrowserNode
Dim l As Long
For l = oSubAssyNode.BrowserNodes.Count To 1 Step -1
If Not oSubAssyNode.BrowserNodes.Item(l).NativeObject Is Nothing Then
If oSubAssyNode.BrowserNodes.Item(l).NativeObject.Type = kComponentOccurrenceProxyObject Then
Set oTargetNode = oSubAssyNode.BrowserNodes.Item(l)
Exit For
Next
Dim oOcc As ComponentOccurrence
Dim oSourceNode As BrowserNode
For Each oOcc In oSelset
Set oSourceNode = oPane.GetBrowserNodeFromObject(oOcc)
'↓↓↓↓↓↓Crashes on this line↓↓↓↓↓↓
Call oPane.Reorder(oTargetNode, False, oSourceNode)
Next
oPane.Update
End Sub
