INVENTOR 2020 CRASHES ON REORDERING NODES
Olsndot
Message 1 of 1
Olsndot
Hi All,
So I have  VBA code to demote the occurrences into sub assembly.
When I run the code, INVENTOR crashes.
Any ideas on this issue?
Sub Demote_into_Assembly()
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oAsmCompDef As AssemblyComponentDefinition
    Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    Dim oSelset As SelectSet
    Set oSelset = oAsmDoc.SelectSet
    If oSelset.Count = 0 Then Exit Sub
    Dim selectAsm As ComponentOccurrence
    Set selectAsm = ThisApplication.CommandManager.Pick _
    (SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select the Assembly to demote the occurrence into [ESC:Cancel]")
    If selectAsm Is Nothing Then Exit Sub
    Dim oPane As BrowserPane
    Set oPane = oAsmDoc.BrowserPanes.Item("Model")
    Dim oSubAssyNode As BrowserNode
    Set oSubAssyNode = oPane.GetBrowserNodeFromObject(selectAsm)
    Dim oTargetNode As BrowserNode
    Dim l As Long
    For l = oSubAssyNode.BrowserNodes.Count To 1 Step -1
        If Not oSubAssyNode.BrowserNodes.Item(l).NativeObject Is Nothing Then
            If oSubAssyNode.BrowserNodes.Item(l).NativeObject.Type = kComponentOccurrenceProxyObject Then
                Set oTargetNode = oSubAssyNode.BrowserNodes.Item(l)
                Exit For
            End If
        End If
    Next
    Dim oOcc As ComponentOccurrence
    Dim oSourceNode As BrowserNode
    For Each oOcc In oSelset
            Set oSourceNode = oPane.GetBrowserNodeFromObject(oOcc)
        '↓↓↓↓↓↓Crashes on this line↓↓↓↓↓↓
            Call oPane.Reorder(oTargetNode, False, oSourceNode)
    Next
    oPane.Update
End Sub
Replies (0)
