Inventor 2017 - default drawing view settings
s_liberatore
s_liberatore
I would set the options
"Threads" and "Tangent Edges" In the Display Option Tab
and
"All bodies" in the Model State tab
in Inventor Drawing View dialox box when I create Inventor View.
I read the discussion at link
http://forums.autodesk.com/t5/inventor-general-discussion/inventor-2016-default-drawing-view-setting...
but I can't to set the options
"Threads" and "Tangent Edges" ON by default.
Can you tell me how have to do?
Thank you.
k14348
Public Sub DisplayOptions()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oDrawingView As DrawingView
Set oDrawingView = oSheet.DrawingViews.Item(1)
Dim oDisplayTangentEdges As Boolean
oDrawingView.DisplayTangentEdges = True
Dim oDisplayThreadFeatures As Boolean
oDrawingView.DisplayThreadFeatures = True
End Sub
If you found this code useful please give KUDOS
k14348
Dim oSheet As Sheet
For Each oDrawingView In oSheet.DrawingViews
If oDrawingView.DisplayTangentEdges = False Then
End If
If oDrawingView.DisplayThreadFeatures = False Then
End If
Next
End Sub
Use this code for All view in a Active sheet
