Inventor 2016: Import STEP File Component Name
Hi all,
Is there an option in Inventor 2016 to use the actual name of component instead of sequence number in importing STEP file?
Kindly refer the attached file.
Thank you.
wayne.brill
Are you using the Inventor API or iLogic in this workflow?
If this is just using the Inventor default user interface to import a STEP file then the question should be posted on the Inventor General forum:
http://forums.autodesk.com/t5/inventor-general-discussion/bd-p/78
If you are using code please provide it so it can be used to recreate and research the problem.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Hi Wayne,
Both default user interface and Inventor API have same output.
See below of the code in importing STEP file. This program is working in Inventor 2011.
Dim oSTEPTranslator As TranslatorAddIn
Dim oContext As TranslationContext
Dim oOptions As NameValueMap
Dim oDataMedium As DataMedium
Dim oTarget As Object
Dim oDoc As Document
Dim i As Integer
For i = 1 To m_InventorApp.ApplicationAddIns.Count
	If m_InventorApp.ApplicationAddIns.Item(i).ClassIdString = "{90AF7F40-0C01-11D5-8E83-0010B541CD80}" Then
		oSTEPTranslator = m_InventorApp.ApplicationAddIns.Item(i)
		Exit For
Next
If oSTEPTranslator Is Nothing Then
	MsgBox("Could not access STEP translator.")
	Exit Sub
oContext = m_InventorApp.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = m_InventorApp.TransientObjects.CreateNameValueMap
oDataMedium = m_InventorApp.TransientObjects.CreateDataMedium
oDataMedium.FileName = strSTEP
If oSTEPTranslator.HasOpenOptions(oDataMedium, oContext, oOptions) Then
	oOptions.Value("EmbedInDocument") = False
	Call oSTEPTranslator.Open(oDataMedium, oContext, oOptions, oTarget)
	oDoc = oTarget
	oDoc.Views.Add()
Hope you can help.
Thanks.
wayne.brill
Thanks for the code example. I am using it to import an .stp I created and I am seeing the component names in the model browser not just numbers. I get this same behavior when opening that step file in the user interface..
To create the step file I opened the stapler.iam in the UI and exported it as an step file. (Stapler.iam is one of the default Inventor Samples).
Please upload a step file that will allow me to recreate the behavior you are getting. Let me know if you want to send it to me privately.
Wayne
Wayne Brill
