Get Informationf of Features and its asscoicated Sketch using API
 I have a model with a list of features and sketch in it.
How do I access the information of the features and its associated sketch using API.
For eg.
I want to extract the information of feature of Sketch1 is Boss-Extrude1 and Sketch2 is Cut-Revolve2 and so on.
Is it possible to get this information from the tree view?
For a reference, I have attached the image of my model too.
cwhetten
Hello.  It appears to be possible.
In a part file:
ThisApplication.ActiveDocument.ComponentDefinition.Sketches will get you the collection of 2D sketches in the part.
Let's say oSketch1 is one of the objects in that collection:
oSketch1.Dependents will get you a collection of objects that includes any features generated from that sketch.  This part is a little tricky because there are probably other objects in that collection--for example, I saw that it included profile objects.  So, you'll have to find a way to loop through the collection and pick out just the dependent features, or maybe filter out anything that isn't a feature.
I hope this is helpful.
Cameron Whetten
Inventor 2016
Thank you for your help.
But I didn't get an idea to use it?
I used your solution in this way:
foreach (PlanarSketch oSketch in oPartDoc.ComponentDefinition.Sketches)
        MessageBox.Show(oSketch.Name);  //its gives the sketch name as Sketch1, but how to get the feature name as Boss-Extrude 1, linked with  Sketch1
         ObjectCollection aa = default(ObjectCollection);
        aa = oSketch.Dependents;
The variable aa gives the number of object i.e. count = 2.
but how do I know the  the information of feature, its name from this soltuion?
I might be wrong using the code, so please suggest me
Regard,
Hello Whetten,
Thank you very much.
I did it using the BrowseNode function.
Thank you in advance. 🙂
Maxim-CADman77
Could you, please, share with us your solution based on BrowseNode ?
Please vote for Inventor-Idea Text Search within Option Names
