Inventor 2016 iLogic and External Rules Folder
AlexFielder
Advisor Advisor
Message 1 of 17
AlexFielder
Hi all,
I have a fairly large amount of iLogic rules stored externally, and I recently decided to do a bit of house keeping by sorting them into folders such as:
Modelling
Drawings
Helper Rules
and so on.
This worked fine until today when I am presented with the following:
I have renamed a couple of the paths in my folder but to no avail.
Thoughts/Ideas?
PS. my list of rule filenames and their respective path lengths are as follows:
rulenamepath length
C:\Users\alex.fielder\Dropbox\iLogic\AddRemove\De-Author.iLogicVb65
C:\Users\alex.fielder\Dropbox\iLogic\AddRemove\Dedupe_and_Hash.iLogicVb71
C:\Users\alex.fielder\Dropbox\iLogic\AddRemove\delete empty folders.iLogicVb76
C:\Users\alex.fielder\Dropbox\iLogic\AddRemove\embed inventor drawings.iLogicVb79
C:\Users\alex.fielder\Dropbox\iLogic\AddRemove\Remove Missing OLE Links.iLogicVb80
C:\Users\alex.fielder\Dropbox\iLogic\AddRemove\Remove Unwanted Linked Parameter Tables.iLogicVb95
C:\Users\alex.fielder\Dropbox\iLogic\AddRemove\Remove Unwanted OLE Links in Inventor Files.iLogicVb99
C:\Users\alex.fielder\Dropbox\iLogic\AddRemove\RemoveColourOverrides.ilogicVb77
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Balloon Filtering iLogic.iLogicVb79
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Batch PDFs from Drawings.iLogicVb79
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\ChangeLayerofOccurrences.iLogicVb79
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\CopySheet.iLogicVb64
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Create_View_Reps.iLogicVb71
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Drawing Automation Code.iLogicVb78
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Drawing Creation Code.iLogicVb76
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Drawing Template - Move and Resize View Code.iLogicVb99
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Export Open Inventor dwgs to AutoCAD.iLogicVb91
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Insert Revision Table.iLogicVb76
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\promptedentrytoiproperty.iLogicVb79
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\RunPlatformDrawings.iLogicVb74
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\SaveAs_PDF_(Single_Or_Multi-sheet).iLogicVb89
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Sketch Symbol Text Changer.iLogicVb81
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Synchronize iProperties between parts and drawings.iLogicVb105
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Text_Changer.iLogicVb67
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Title Block Definition Create and Insert API Sample.iLogicVb106
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Turn Sketch Symbol Leaders on.iLogicVb84
C:\Users\alex.fielder\Dropbox\iLogic\Drawings\Turn View Labels on.iLogicVb74
C:\Users\alex.fielder\Dropbox\iLogic\Helper Rules\Ground_and_Root.iLogicVb74
C:\Users\alex.fielder\Dropbox\iLogic\Helper Rules\iProperties.iLogicVb70
C:\Users\alex.fielder\Dropbox\iLogic\Helper Rules\Parameters.iLogicVb69
C:\Users\alex.fielder\Dropbox\iLogic\Helper Rules\PartsandAssemblies.iLogicVb77
C:\Users\alex.fielder\Dropbox\iLogic\Helper Rules\ProcessPartFilesInaFolder.iLogicVb84
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\AlignUCSToAssy.iLogicVb70
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\All Sketches Off In Assembly.iLogicVb84
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\All Sketches Off In Part.iLogicVb80
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\CaptureSketchBlockLocations.iLogicVb83
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Check Sketch Constraints.iLogicVb80
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\CheckForCURequired.iLogicVb74
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\CheckiPartForErrors.iLogicVb75
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Compare File volumes.iLogicVb76
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Contact Constraint Simulation.iLogicVb85
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Copy_Camera_to_open_documents.iLogicVb85
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Create a New iLogic Rule automatically.iLogicVb94
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Create Drawings From Assembly.iLogicVb85
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Create DT- Drawings From Assembly.iLogicVb89
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Create DT- View Reps From Assembly.iLogicVb90
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Create_Assembly_from_Excel.iLogicVb82
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Create_Balconies.iLogicVb72
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Create_Cables.iLogicVb69
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Create_Labels.iLogicVb69
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Create_standard_parts_from_Excel.iLogicVb88
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\CS Data Standards.iLogicVb73
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\DesignCheckerResultsFromAssembly.iLogicVb88
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Export Part to Step (Stage by Stage).iLogicVb92
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Export to 3D PDF and Attach or Embed.iLogicVb92
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\FEATURECOUNT.iLogicVb68
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Flat pattern save as dxf.iLogicVb80
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Generate iPart Members from Folder.iLogicVb90
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Generate iPart Members from Parent Assemblies.iLogicVb101
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Generate iPart Members.iLogicVb78
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Ground&RootSelectedComponents.iLogicVb85
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\HyperLink to Excel.iLogicVb74
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Inventor 2016 - ILogic to write Parameter to every part in the Assembly.iLogicVb127
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\MakeComponentsProgramatically.iLogicVb85
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\MetalShopPn.iLogicVb67
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\MirrorPartInAssembly.iLogicVb76
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Move EOPs In Assembly.iLogicVb77
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\MoveToPlane.iLogicVb67
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\PrintRibbonInformation.iLogicVb78
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Rename Parameters.iLogicVb73
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Replace references from external list.iLogicVb93
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\run design checker on each component.iLogicVb92
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\RunCorrectBomForExcel.iLogicVb77
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\RunCreateAssemblyFromiLogic.iLogicVb83
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\RunCreateAssemblyFromiLogic_UPLOAD.iLogicVb90
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\RunExportToMultipleFormats.iLogicVb82
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\RunFeatureCountonAssembly.iLogicVb81
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\RunGraitecPartCreator.ilogicVb77
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Selective Colour Change.iLogicVb79
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Suppress Weld Prep.iLogicVb74
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\sweep-length-code-snippet.iLogicVb81
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Synchronize iProperties between part parameters and iProperties.iLogicVb119
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Toggle Sketches and Workplanes.iLogicVb86
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Turn On-Off all Workfeatures with iLogic.iLogicVb96
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\under constrained sketches.iLogicVb82
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\UpdatedCurrentlyOpenDocuments.iLogicVb85
C:\Users\alex.fielder\Dropbox\iLogic\Modelling\Workplane Grid Creator.iLogicVb78
C:\Users\alex.fielder\Dropbox\iLogic\Module Rules\Modules.ilogicvb66
C:\Users\alex.fielder\Dropbox\iLogic\Module Rules\Update.iLogicVb65
C:\Users\alex.fielder\Dropbox\iLogic\PJ\06 Add Size To Parts.iLogicVb69
Is there some unwritten rule dictating how many of these you can have? Or perhaps the path length is too much for iLogic to cope with? (This latter point shouldn't be possible as even the longest path there is < half the 255 character path length (albeit loosely) enforced in Windows itself)
Alex.
Replies (16)
Message 2 of 17
AlexFielder
Ho hum; As usual,
It seems a workaround for this is to add each sub-folder individually:
And then Inventor is quite happy to display them all:
Regardless, it would be nice to know what the limiting factor is.
Message 3 of 17
MjDeck
Hi Alex,
One benefit of the workaround: it reduces the number of levels in the tree 🙂
The limit is 3000 files or 200 subfolders (at any level). We could increase them a bit in the next release. What would you recommend?
The main reason for the limits is to catch cases where somebody might select the whole C:\ drive (or other large folder) by mistake.
Mike Deck
Software Developer
Autodesk, Inc.
Message 4 of 17
AlexFielder
Hi @MjDeck,
Thanks for the information.
The weird thing is that I didn't have either 3000 files or 200 sub-folders but still Inventor threw the dummy in the dirt and refused to allow me to have any sub-folders whatsoever.
Are there file extensions or other restrictions that might have been affecting my experience?
Alex.
Message 5 of 17
JarFu
Hi Alex,
As Mike mentioned, it should only count files with the following extensions:
.iLogicVb
.vb
.txt
We tried locally with Inventor 2016 but not reproduce the issue as yours. Could you please lets know if there is any file special under your iLogic folder?
And the warning message popup as attached if there are 3000+ files under the selected folder. What's the error did you get? Please attach if possible. Many thanks!
Jar Fu
SW Engineer
Inventor QA
Autodesk, Inc.
Message 6 of 17
Would you consider sharing some of those external rules you have for others to learn from and build upon? A few of them by their titles interest me greatly!
Message 7 of 17
Most of them appear to be here.
https://github.com/AlexFielder/iLogic
Message 8 of 17
Thank you!!
Message 9 of 17
Is it possible that .Vb files from other programs are being picked up even though they are not in the same exact file path. Because I am getting this error and I've never even created an iLogic rule in inventor.  I do however have an ERP database that has thousands of them. None of these are under anything to do with inventor though. They are just on the same drive.
Message 10 of 17
AlexFielder
So, here I am nearly five years to the day since the original post and amazingly, this is still an issue.
I have the following subfolder:
C:\Users\alex.fielder\OneDrive\Documents\GitHub\ManAndMachine\MandM-iLogic
which contains 801 objects (of which only 218 are files) because:
  1. I use git to track changes to iLogic rules
  2. I use VSCode and it's "Local History" extension to provide me a backup of changed files in case I mess something up and don't want to revert changes using git.
The number of actual .iLogicVb files in that folder is 21.
21 iLogic files and Inventor is all "too many files or subdirectories y'all":
Yes, I can just add the individual folders like I did before, but how much effort is it to update Inventor/the iLogic subsystem to include a .iLogicIgnore file (copy the git .gitignore mechanism) or something..?
then I could simply add these lines to it:
.git/
.history/
.nppbackup/
and all would be fine.
Message 11 of 17
AlexFielder
I just realised I made a typo in the above reply: the reason Inventor gets upset is because I have this morning just tipped over the hard limit @MjDeck alluded to of 200 folders. Likely because I am using git to monitor changes. 😅
Message 12 of 17
MjDeck
@AlexFielder , sorry about that. As you say, we should have relaxed this limit by now. And there is no reason to show the files in the .git folder in the iLogic browser.
The .git folder is hidden, so it would be relatively easy for iLogic to ignore it. However, the .history folder maintained by VS Code Local History is not hidden. So a .iLogicIgnore file sounds like the way to go.
Are you running Inventor 2022?
Mike Deck
Software Developer
Autodesk, Inc.
Message 13 of 17
AlexFielder
Hi @MjDeck,
Thanks for replying.
Yes, I am running Inventor 2022. I can obviously make the .History folder a hidden folder if that helps things..?
Message 14 of 17
MjDeck
Will VS Code Local History work just as well if the .history folder is hidden?
You also have the .nppbackup directory.
It shouldn't be too much more work to add support for a .iLogicIgnore file.
Mike Deck
Software Developer
Autodesk, Inc.
Message 15 of 17
AlexFielder
I modified the .history folder to hidden this morning and it hasn't so much as twitched about it. The .nppbackup folder is Notepad++ and it doesn't care about that folder being set to hidden either.
Message 16 of 17
MjDeck
Thanks for testing. Based on your results, we'll probably concentrate on hidden folders for the fix. We can also increase the limits on visible files and folders. This is internal issue INVGEN-56201.
Mike Deck
Software Developer
Autodesk, Inc.
Message 17 of 17
AlexFielder
I notice this is fixed in the Inventor 2022.2 patch notes. Great work team!
