Inventor 2014
Inventor 2014
Inventor 2014
We are in the process to upgrade the MS office version from 2007 to 2016 so just wanted to know if there are any known compatibility issues between office 2016 and Inventor 2014?
Manish Sharma
Owner2229
Hi, I'm not aware of any major issues. The only one I was able to find is about Office 365:
https://knowledge.autodesk.com/.../Office-365
Just don't forget to uninstall everthing Office 2007 related and if you can, even clean registry of it.
Shall any issues arise, you can use this solution:
1) Uninstall both Office and Inventor
2) Clean registry files
3) Install Office
4) Install Inventor
You can do it like this with the MS upgrade, but it's some extra work (and time) and usually not needed (90%).
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
