Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Inventor 2013. FileDialog that does not point to current project?
Message 1 of 16
I'd like to create a filedialog that points to the IntitialDirectory property location.  Not the current project.
It doesn't look like the filedialog object uses the InitialDirectory property at all.  Anyway to fix it?
Replies (15)
Message 2 of 16
Vladimir.Ananyev
May be this link could be useful:
http://adndevblog.typepad.com/manufacturing/2012/12/overriding-the-inventor-native-file-open-and-fil...
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 3 of 16
1) I am using VBA here not VB.NET.  So the first suggestion of your link does not apply.
2) The second suggestioin basically says to use the InitialDirectory property of the inventor openfiledialog.
This as I said previously appears to be broken.
I use to use the WinAPI to launch File and Folder broswer dialogs.  I cannot get them to work with 64 bit VBA 7.
It would be nice if someone from Autodesk posted them for that envioronment.  I have managed to get
all my other WinAPI tools working by using ptrsafe, longlong, and ptrlong, but not the above.
I made a workaround by creating an Addin in VB.NET that exposes file and folder browsing dialogs.
I call them from VBA.  Seems rediculous to me I have to go to such lengths.
Message 4 of 16
Vladimir.Ananyev
InitialDirectory property allows you set any directory that will be used when the dialog is initially displayed.
WorkspacePath property of the DesignProject object is useful if you need to open the current workspace.
Here is VBA sample:
Public Sub TestFileDialog()
    ' Set a reference to the DesignProjectManager object.
    Dim oDesignProjectMgr As DesignProjectManager
    Set oDesignProjectMgr = ThisApplication.DesignProjectManager
    'current workspace path
    Dim sPath As String
    sPath = oDesignProjectMgr.ActiveDesignProject.WorkspacePath
    ' Create a new FileDialog object.
    Dim oFileDlg As FileDialog
    Call ThisApplication.CreateFileDialog(oFileDlg)
    ' Define the filter to select part and assembly files or any file.
    oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
    ' Define the part and assembly files filter to be the default filter.
    oFileDlg.FilterIndex = 1
    ' Set the title for the dialog.
    oFileDlg.DialogTitle = "Open File Test"
    ' Set the initial directory that will be displayed in the dialog.
    oFileDlg.InitialDirectory = sPath   '"C:\Temp"
    ' Set the flag so an error will be raised if the user clicks the Cancel button.
    oFileDlg.CancelError = True
    ' Show the open dialog.  The same procedure is also used for the Save dialog.
    ' The commented code can be used for the Save dialog.
    On Error Resume Next
    oFileDlg.ShowOpen
'    oFileDlg.ShowSave
    ' If an error was raised, the user clicked cancel, otherwise display the filename.
    If Err Then
        MsgBox "User cancelled out of dialog"
    ElseIf oFileDlg.FileName <> "" Then
        MsgBox "File " & oFileDlg.FileName & " was selected."
    End If
End Sub
Vladimir Ananyev
Message 5 of 16
I do not think you are hearing me.
I know how to use the inventor file dialog.  Been using it for years.
I do not want the workspace path.
I am not trying to load inventor files.
In 2013 when I set the  InitialDirectory property  to "C:\" is opens a the last used inventor path not "C:\"
Message 6 of 16
jdkriek
This works fine for me in 2013:
oFileDlg.InitialDirectory = "C:\"
    oFileDlg.Filter = "All Files (*.*)"
    oFileDlg.ShowOpen
    If Err Then
        MsgBox "User cancel"
    End If
End Sub
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 7 of 16
Ahhhhh!
Discovered the issue.  Due to a network error my desired initialDirectory was not available.
The problem is that the Inventor File Dialog does not error out when given a bad initial directory.
It just defaults to the last used.directory.
I can work around this by checking for the folder (with error handling) before I use the dilaog.
Still I find the filedialog behaviour odd ball.
Message 8 of 16
jdkriek
Bingo!
' Include REF to Microsoft Scripting Runtime
    Dim FSO As New Scripting.FileSystemObject
    Dim Path As String
    Path = "C:\path\"
        If FSO.FolderExists(Path) Then
            ' Continue
        Else
            MsgBox ("Folder Does Not Exist")
            Exit Sub
        End If
        With oFileDlg
            .InitialDirectory = Path
            .CancelError = True
        End With
    oFileDlg.ShowOpen
    If Err Then
        MsgBox ("File " & oFileDlg.FileName & " was selected")
    End If
End Sub
Jonathan D. Kriek
Message 9 of 16
Personally I do not like the FileSystemObject.for VBA.
Way slow and bloated.
For file and folder checks I use the following two functions.
Many orders of magnitude faster than Dir$() or FSO.when
looping.
Public Function FileExists(ByVal sFilename As String) As Boolean
  Dim att As Long
  att = GetAttr(sFilename)
  If Err.Number = 0 Then
    FileExists = True
  Else
    Err.Clear
    FileExists = False
  End If
  On Error GoTo 0
End Function
Public Function FolderExists(ByVal sFolderName As String) As Boolean
  Dim att As Long
  att = GetAttr(sFolderName)
    FolderExists = True
  Else
    Err.Clear
    FolderExists = False
  End If
  On Error GoTo 0
End Function
Message 10 of 16
jdkriek
Indeed, about 25% faster - but FSO still finds it in less than second for me 😉
Jonathan D. Kriek
Message 11 of 16
Agreed.  As I have to support a large group of users I prefer to have a few object reference dependencies as possible.  This is only with VBA though.  Not a problem with compiled apps.  If things ever settle down I plan to port everything to VB.NET or C#.  Of course they haven't settled down for that last ten years. Smiley Wink
Message 12 of 16
jdkriek
I know exactly what you mean 😉
I've been slowing converting to VB.NET myself, but they keep throwing wrenches at me.
Jonathan D. Kriek
Message 13 of 16
Crstiano
Hi, Jonathan,
I have the similar problem, but in .NET VS2010
When use FileDialog, appears this Warning
Variable 'oFileDlg' is passed by reference before it has been assigned a value. A null reference exception could result at runtime.
any ideia?
Cristiano Oliveira
ConsultCAD.com
Message 14 of 16
Unless you post the relevant code we cannot answer the question.
Message 15 of 16
ekinsb
The following code will result in the warning you listed.
Dim fDialog As Inventor.FileDialog
invApp.CreateFileDialog(fDialog)
 Initializing the variable, as shown below, will get rid of the warning.
Dim fDialog As Inventor.FileDialog = Nothing
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
Message 16 of 16
do you mind sharing your folder error handling...
i have exactly the same error as you..
initialdirectory doesnt work for me....Smiley FrustratedSmiley Frustrated
