Inventor 2012 -ILogic imates Update
I have an assembly in which I have imates. imates are created usign work planes. Now as soon as I move the work planes ( Increasing the work plane dimension) my imates does not move. See the Picture below. Now, I have been using "Rebuild all" Command to fix this issue. But the problem now is that I have a big assembly with 100's of parts and using "Rebuild all" command takes very long time to execute. Is it possible to update just the imates in the assembly or update just the subassembly where imates are. Can somebody provide me the code for that.
Regards!
Varinder
waynehelley
I am looking for the same thing.
A method to update iMates without having to do a rebuild all.
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
xiaodong_liang
Autodesk Support
Autodesk Support
Hi varindersra,
 I do not find a way to update imate only. Probably AssemblyDocument.Rebuild2() may help. It performs compute operations on all of the entities within this Document's scope as if all of the driving entities had been 'dirtied'.
