Inventor 2011: Inventor View Ctrl OCX registrati​on error..
In MS VB.NET 2010 Standard I Browsed to: C:\Program Files\Autodesk\Inventor 2011\Bin\InventorViewCtrl.ocx
And Selected it for a COM reference.  This generated Interop.InventorViewControlLib.
I added the control to the VB.NET toolbox with the Choose Item tool.
At this point VB.NET will not let me add the control to a form.  When I try to draw the control I get the followng.
Microsoft Visual Studio Error:
Failed to import the ActiveX control.  Please ensure it is properly registered.
This use to work with VB.NET 2005.  What can I do to resolve this issue?
Problem Solved.
Apparently I was starting a MS 2010 VB.NET project with MS DotNet Framework v4.0
Rolling the project back to MS DotNet Framework v3.5 fixed the issue.
