Inventor 2011 - Confusion with millimeters and centimeters
In a VBA customization I have some problem.
When I get the dimension of a sheet metal with 700 x 750 mm
Inventor understand 7000 x 7500mm
How can I set Inventor from VBA code to accept dimensions as milimeters?
Thanks in advance.
ekinsb
In the API whenever there are values returned that represent lengths they will ALWAYS be in centimeters.  You can't change that.  Inventor, and the API, use a consistent set of units internally and the API exposes this publicly.
Brian Ekins
Mod the Machine blog
Thanks a lot Brian.
