Invalid Parameter when trying to set parameter.expression HRESULT: 0x80070057
hozz__
Message 1 of 1
hozz__
I'm having difficulty with a seemingly simple bit of code, assigning a string to MyParam.Expression in the code below fails with INVALID PARAMETER error HRESULT: 0x80070057
AllParams is a previously loaded ParameterList
MyParam.Expression = MyString is the statement that fails.
    Private Sub SaveParameter(ByVal aParamName As String, ByVal NewExpression As String)
        Dim MyString As String
        Dim MyParam As Parameter
        For i = 1 To AllParams.Count
            If AllParams.Item(i).Name = aParamName Then
                MyParam = AllParams.Item(i)
                MyString = NewExpression
            End If
        Next
    End Sub
AnyHelp would be appreciated,
Marv
Replies (0)
