Inserting an Ifeature into a part from a table using VBA
austen_27_t
Message 1 of 8
austen_27_t
I am trying to make a program where you will be able to select an Ifeature and a part from a drop down meanu and it be placed into a basic part. Currently i just want to get the code to place the Ifeature on the separate part that is open in inventor.
I am using the code from the inventor help site, but it is not working. The error arises at the very last line of code.
Ive adjusted it a little to get my files to work in it.
I would appreciate any help
Thank You
Public Sub TableIfeature()
' Get the part document and component definition of the active document.
On Error Resume Next
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
If Err Then
MsgBox "A part must be active."
Exit Sub
Dim oPartDef As PartComponentDefinition
Set oPartDef = oPartDoc.ComponentDefinition
' Get the selected face to use as input for the iFeature.
Dim oFace As Face
Set oFace = oPartDoc.SelectSet.Item(1)
If Err Then
MsgBox "A planar face must be selected."
Exit Sub
On Error GoTo 0
If oFace.SurfaceType = kPlaneSurface Then
Exit Sub
Dim oFeatures As PartFeatures
Set oFeatures = oPartDef.Features
' Create an iFeatureDefinition object.
Dim oiFeatureDef As iFeatureDefinition
Set oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("C:\CAD_Work\MX.ide")
Dim bFoundPlaneInput As Boolean
bFoundPlaneInput = False
Dim oInput As iFeatureInput
For Each oInput In oiFeatureDef.iFeatureInputs
Dim oParamInput As iFeatureParameterInput
Select Case oInput.Name
Case "Profile Plane1"
Dim oPlaneInput As iFeatureSketchPlaneInput
Set oPlaneInput = oInput
oPlaneInput.PlaneInput = oFace
bFoundPlaneInput = True
End Select
Next
If Not bFoundPlaneInput Then
MsgBox "The ide file does not contain an iFeature input named ""Profile Plane1""."
Exit Sub
'** Look through the table to find the row where "Size" is "4.5".
Dim oTable As iFeatureTable
Set oTable = oiFeatureDef.iFeatureTable
' Find the "Size" column.
Dim oColumn As iFeatureTableColumn
Dim bFoundSize As Boolean
bFoundSize = False
For Each oColumn In oTable.iFeatureTableColumns
If oColumn.DisplayHeading = "MEMBER" Then
bFoundSize = True
Exit For
Next
If Not bFoundSize Then
MsgBox "The column ""Size"" was not found."
Exit Sub
' Find the row in the "Size" column with the value of "4.5"
Dim oCell As iFeatureTableCell
bFoundSize = False
For Each oCell In oColumn
If oCell.Value = "5120-MS0F-M8" Then
bFoundSize = True
Exit For
Next
MsgBox "The cell with value ""4.5"" was not found."
Exit Sub
' Set this row as the active row.
oiFeatureDef.ActiveTableRow = oCell.Row
' Create the iFeature.
Dim oiFeature As iFeature
Set oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
End Sub
Replies (7)
Message 2 of 8
clutsa
I set this to a iFeature of my own and it works fine. Are you sure you're finding a row?
If Err Then
Exit Sub
Dim oFace As Face
If Err Then
Exit Sub
On Error GoTo 0
If NOT oFace.SurfaceType = kPlaneSurface Then
Exit Sub
End Select
Next
Exit Sub
bFoundSize = False
If oColumn.DisplayHeading = "MEMBER" Then '<--this needs to be "Size"
bFoundSize = True
Exit For
Next
MsgBox "The column ""Size"" was not found." '<--Are you looking for size or member?
Exit Sub
bFoundSize = False
bFoundSize = True
Exit For
Next
Exit Sub
End Sub
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 3 of 8
austen_27_t
I found out the problem earlier today. The iFeatures i was creating had two selectable position geometries, a planar face and a revolve axis. So now i need to find out how to add in code that would allow me to also select a revolve axis for my ifeature.
Message 4 of 8
clutsa
Would something like this work?
RevAxis = ThisApplication.CommandManager.Pick(kAllLinearEntities, "Pick a revolved axis")
you could use it to pick the face too
Dim oFace As Face
'Set oFace = oPartDoc.SelectSet.Item(1)
Set oFace = ThisApplication.CommandManager.Pick(kAllPlanarEntities, "Pick a planar face")
Message 5 of 8
austen_27_t
What would i Dim RevAxis as?
Message 6 of 8
austen_27_t
Also i would need to call out the axis as another case so it needs to be defined as an input
Message 7 of 8
clutsa
I agree it would have to be defined as an input. Could you post your .ide file and I can take a look. It's hard to tell you what it needs to be without the file itself (I only got this far because I had a .ide of my own creation but I don't really want to make another just for testing)
Message 8 of 8
austen_27_t
It is not letting me post the ide file. I have attached a screen shot of the position geometry and the ipt file
