Error face not planar on selected part VBA Ifeature
austen_27_t
austen_27_t
I am trying to insert an i feature just into a basic cube using the code from the inventor help desk but no matter what face i choose i get the planar face needs to be selected error.
I have tried selecting all faces of the cube but none seem to work can anyone tell me why and how to fix?
Public Sub PlaceTableDriveniFeature()
' Get the part document and component definition of the active document.
On Error Resume Next
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
If Err Then
MsgBox "A part must be active."
Exit Sub
Dim oPartDef As PartComponentDefinition
Set oPartDef = oPartDoc.ComponentDefinition
' Get the selected face to use as input for the iFeature.
Dim oFace As face
Set oFace = oPartDoc.SelectSet.Item(1)
If Err Then
MsgBox "A planar face must be selected."
Exit Sub
On Error GoTo 0
If oFace.SurfaceType = kPlaneSurface Then 'When this is added error message occurs
Exit Sub
Dim oFeatures As PartFeatures
Set oFeatures = oPartDef.Features
' Create an iFeatureDefinition object.
Dim oiFeatureDef As iFeatureDefinition
Set oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("C:\CAD_Work\MX.ide")
' Set the input, which in this case is only the sketch plane
' since the other input comes from the table. The parameter input
' should not be available at this point since it can't be changed
' and is controlled by the table.
' When an existing table driven iFeature is accessed then this should
' include the parameters so the programmer has access to the corresponding
' reference parameter that's created.
Dim bFoundPlaneInput As Boolean
bFoundPlaneInput = False
Dim oInput As iFeatureInput
For Each oInput In oiFeatureDef.iFeatureInputs
Dim oParamInput As iFeatureParameterInput
Select Case oInput.Name
Case "Profile Plane1"
Dim oPlaneInput As iFeatureSketchPlaneInput
Set oPlaneInput = oInput
oPlaneInput.PlaneInput = oFace
bFoundPlaneInput = True
End Select
Next
If Not bFoundPlaneInput Then
MsgBox "The ide file does not contain an iFeature input named ""Profile Plane1""."
Exit Sub
'** Look through the table to find the row where "MEMBER" is "M8".
Dim oTable As iFeatureTable
Set oTable = oiFeatureDef.iFeatureTable
' Find the "Size" column.
Dim oColumn As iFeatureTableColumn
Dim bFoundSize As Boolean
bFoundSize = False
For Each oColumn In oTable.iFeatureTableColumns
If oColumn.DisplayHeading = "MEMBER" Then
bFoundSize = True
Exit For
Next
If Not bFoundSize Then
MsgBox "The column MEMBER was not found."
Exit Sub
' Find the row in the "MEMBER column with the value of "M8"
Dim oCell As iFeatureTableCell
bFoundSize = False
For Each oCell In oColumn
If oCell.Value = "M8" Then
bFoundSize = True
Exit For
Next
MsgBox "The cell with value M8 was not found."
Exit Sub
' Set this row as the active row.
oiFeatureDef.ActiveTableRow = oCell.Row
' Create the iFeature.
Dim oiFeature As iFeature
Set oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
End Sub
clutsa
I didn't check this whole thing but I did see this...
If Err Then
    Exit Sub
Dim oFace As Face
If Err Then
    Exit Sub
On Error GoTo 0
If Not oFace.SurfaceType = kPlaneSurface Then 'When this is added error message occurs <----- ADDED 'NOT'
    Exit Sub
End Select
Next
    Exit Sub
bFoundSize = False
        bFoundSize = True
        Exit For
Next
    Exit Sub
bFoundSize = False
        bFoundSize = True
        Exit For
Next
    Exit Sub
End Sub
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
austen_27_t
This was one of the errors in the inventor help desk
I still have another error in that code that i just posted but thank you!
clutsa
Looks like your loops are broken up to much...
If Err Then
    Exit Sub
Dim oFace As Face
If Err Then
    Exit Sub
On Error GoTo 0
    Exit Sub
Set oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("C:\Vault\Workspace\Parts\iFeatures\SAE ORB Port.ide")
    End Select
Next
    Exit Sub
'** Look through the table to find the column where header is "MEMBER".
bFoundSize = False
        bFoundSize = True
                Exit For
        Next
        Exit For
Next
    Exit Sub
End Sub
austen_27_t
Ill give this a try but my error comes in the last line. Ill see if this might fix it
Thank You
