insert sketch in drawing
GKR2023
GKR2023
Hello.
I am useing this code:
https://forums.autodesk.com/t5/inventor-programming-ilogic/insert-sketch-symbol-using-ilogic/td-p/43...
And adjusted it a bit:
Sub Main()
Dim oDoc As Document = ThisDoc.Document
If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
	MsgBox("Active document is not a drawing")
	Exit Sub
End If
	Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
	Dim oSheet As Sheet = oDrawDoc.ActiveSheet
	Dim oSketchedSymbolDef As SketchedSymbolDefinitions = oDrawDoc.SketchedSymbolDefinitions.Item("Sheet Metal DXF-/STEP-file")
	Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(oSheet.Border.RangeBox.MaxPoint.X, oSheet.Border.RangeBox.Y)
	Dim oSketchedSymbol As SketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef,oInsertionPoint, 0.0, 1.0, Nothing)
End Sub
But I get the following error on rule 11.
The symbol is there.
What am I doing wrong?
Ciao
JelteDeJong
It looks like your sketched symbol is in a library file. You need to copy it first to your drawing the you can use it. Try this:
Dim doc As Document = ThisDoc.Document
If doc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
    Exit Sub
End If
Dim sheet As Sheet = doc.ActiveSheet
Dim project = ThisApplication.DesignProjectManager.ActiveDesignProject
Dim libraryPath = System.IO.Path.Combine(project.DesignDataPath, "Symbol Library\Library.idw")
Dim libDoc = ThisApplication.Documents.Open(libraryPath, False)
Dim sketchedSymbolDef As SketchedSymbolDefinition = libDoc.SketchedSymbolDefinitions.Item("Sheet Metal DXF-/STEP-file")
sketchedSymbolDef = sketchedSymbolDef.CopyTo(doc, True)
libDoc.Close(True)
Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(sheet.Border.RangeBox.MaxPoint.X, sheet.Border.RangeBox.MaxPoint.Y)
sheet.SketchedSymbols.Add(sketchedSymbolDef, oInsertionPoint, 0.0, 1.0, Nothing)
Jelte de Jong
Blog: hjalte.nl - github.com
GKR2023
This worked! Thank you for the explanation!
Ciao
