Insert revision table using bottom left corner with iLogic?
skatzY7HV8
skatzY7HV8
Based on the documentation and the helpful users of this forum, I've got an iLogic rule to automatically place a revision table of a specific style into a drawing. However, this inserts the revision table using the top left corner as the insertion point (our revision table adds new rows going up instead of going down).
Is it possible to use the bottom left corner as the insertion point on a revision table?
Stephen
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.ActiveSheet
Dim oWidthRevTable As Double
oWidthRevTable = oDrawingDoc.UnitsOfMeasure.ConvertUnits(7+39/64,"in","cm") 'Set you custom width table
'Add Revision table
Dim oTablePt As Point2d
oTablePt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Border.RangeBox.MaxPoint.X - oWidthRevTable, oSheet.TitleBlock.RangeBox.MaxPoint.Y)
If oSheet.RevisionTables.Count = 0 Then
	Dim oRevTableId As RevisionTableStyle
    	oRevTableId = oDrawingDoc.StylesManager.RevisionTableStyles.Item("ABC RevTable")
	Dim oRevTable As RevisionTable
	oRevTable = oSheet.RevisionTables.Add2(oTablePt, True, True, True, "0", oRevTableId, )
Else
    MessageBox.Show("Revision Table already exist", "Autodesk Inventor")
End If
JamieVJohnson2
So the table is hard-wired to use the upper left corner for its position.  This means during insert that's the only point you get.  However, you can calculate the desired position of that point also using revisiontable.rangebox to offset it vertically as well.  You can even drop the table, let it draw in full, modify rows ect, then move the table after calculating its size limits(rangebox) vs the position property (upper left corner).
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
skatzY7HV8
Unfortunate that that is the case, but not a difficult workaround.
Dim oSheet As Sheet
'Add Revision table
oTablePt = ThisApplication.TransientGeometry.CreatePoint2d(0,0)
	Dim oRevTableStyle As RevisionTableStyle
    oRevTableStyle = oDrawingDoc.StylesManager.RevisionTableStyles.Item("ABC Revision Table")
	oRevTable = oSheet.RevisionTables.Add2(oTablePt, True, True, True, "0", oRevTableStyle, )
Else
End If
Dim oRevTableItem As RevisionTable
oRevTableItem = oSheet.RevisionTables.Item(1)
oWidthRevTable = oRevTableItem.RangeBox.MaxPoint.X - oRevTableItem.RangeBox.MinPoint.X
Dim oHeightRevTable As Double
oHeightRevTable = oRevTableItem.RangeBox.MaxPoint.Y - oRevTableItem.RangeBox.MinPoint.Y
oTablePt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Border.RangeBox.MaxPoint.X - oWidthRevTable, oSheet.TitleBlock.RangeBox.MaxPoint.Y + oHeightRevTable)
oRevTableItem.Position = oTablePt
