Insert multiple components from excel
kpk7VYPK
Message 1 of 11
kpk7VYPK
Hi, I have the following code, which does what I want it to do, but is there a way to write it so that I can do one line of the 'component.add' code and it finds all the cells in the excel sheet that contain data and insert them all without having to specify the row number?
Dim sFile As String = "C:\VaultWorkspace\Designs\PROJ Skiold\Personlige\KPK\"& cstr (iProperties.Value("Project", "Part Number")) & " DK250S Config.xlsx"
GoExcel.Open(sFile, "Test")
Dim FirstCol = "A"
Dim FirstRow = "2"
Dim componentA = Components.Add("" , "CO_D" & CStr(GoExcel.CellValue(sFile, "Test", FirstCol & FirstRow)) & ".ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
Dim componentB = Components.Add("", "CO_D" & CStr(GoExcel.CellValue(sFile, "Test", FirstCol & (1+FirstRow))) & ".ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
Dim componentC = Components.Add("", "CO_D" & CStr(GoExcel.CellValue(sFile, "Test", FirstCol & (2+FirstRow))) & ".ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
Dim componentD = Components.Add("", "CO_D" & CStr(GoExcel.CellValue(sFile, "Test", FirstCol & (3+FirstRow))) & ".ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
Replies (10)
Message 2 of 11
FINET_Laurent
Hi @kpk7VYPK,
Sure, here is a small code that does just this :
Dim sFile As String = "C:\VaultWorkspace\Designs\PROJ Skiold\Personlige\KPK\"& CStr (iProperties.Value("Project", "Part Number")) & " DK250S Config.xlsx"
Dim FirstCol = "A"
Dim FirstRow = "2"
For i As Integer = 0 To 999
	Dim val As String = CStr(GoExcel.CellValue(sFile, "Test", FirstCol & (FirstRow + i)))
	If val Is Nothing Then Exit For
	Components.Add("" , "CO_D" & val & ".ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
Next
Does this suits your needs?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 11
kpk7VYPK
Thanks so much! Been trying to figure this out for ages!
Message 4 of 11
kpk7VYPK
Ok here is another puzzle on the same code. I have UCS points on each part for constraining and had previously written this code. But now the components arent specified by name. Is there a way to make this work?
Constraints.AddUcsToUcs("UcsToUcs1", componentA , "UCS_turnsection", componentB, "UCS_turnsection", xOffset := 0, yOffset := 0, zOffset := 0)
Constraints.AddUcsToUcs("UcsToUcs2", componentB, "UCS_drivesection", componentC, "UCS_turnsection", xOffset := 0, yOffset := 0, zOffset := 0)
Constraints.AddUcsToUcs("UcsToUcs3", componentC, "UCS_drivesection", componentD, "UCS_drivesection", xOffset := 0, yOffset := 0, zOffset := 0)
Message 5 of 11
FINET_Laurent
Hi @kpk7VYPK,
Note you can mark multiple replies as "solution" on your topic. Here is a code that would do it :
Dim FirstCol = "A"
Dim FirstRow = "2"
Dim prevComp As ManagedComponentOccurrence
	Dim newComp = Components.Add("" , "CO_D" & val & ".ipt", position := Nothing, grounded := False, visible := True, appearance := Nothing)
	If i <> 0 Then Constraints.AddUcsToUcs("UcsToUcs1", prevComp, "UCS_turnsection", newComp, "UCS_turnsection", xOffset := 0, yOffset := 0, zOffset := 0)
	prevComp = newComp
Next
Kind regards,
FINET L.
Message 6 of 11
kpk7VYPK
Thanks, I am running into this error:
Message 7 of 11
FINET_Laurent
@kpk7VYPK,
Weird, the code is running fine on my end. I added the declaration of "newComp" on line 6:
Dim FirstCol = "A"
Dim FirstRow = "2"
Dim prevComp, newComp As ManagedComponentOccurrence
	prevComp = newComp
Next
Does this fix the problem?
Kind regards,
FINET L.
Message 8 of 11
kpk7VYPK
Oh sorry i hadn't copied in the whole new code. It works somewhat, but not 100% due to the different UCS names (turn section, drive section ,etc). Its a long winded solution I am exploring so I am not even sure it is possible to make work. 😐
Message 9 of 11
FINET_Laurent
@kpk7VYPK,
Indeed it would be dificult to make the code work if the logic in the UCS names is not consistent.
Can you explain us a bit more about the naming logic? We might find something.
How many components are there ?
Kind regards,
FINET L.
Message 10 of 11
kpk7VYPK
Its a kind of 'configurator' I am trying to code as an interim solution until we get a fully integrated configurator. It is for different transport machines, like conveyor belts etc. So there are many different components and constraint names that need to be connected. Getting the parts into the assembly from the code you sent is a huge step forward, at least this way we can use the BOM from inventor and manually do the constraints.  🙏
Message 11 of 11
kpk7VYPK
Hi again, thanks so much for your help yesterday. My code is coming along nicely. One area i am stuck is to get the components.add part of the code to place the parts into the assembly multiple times based on data in the excel sheet. I have worked out how to override the BOM, but i dont think that is good enough. I need the parts to be added in multiple times. Any way to do this?
Thanks 🙂
