Insert multiple assemblies to idw top left isometric view
Thanks in advance for reading
I have to make alot of quick views for our catalogue.
From dozens of assemblies I should have a topleft isometric view (idw).
Drag-and-drop from explorer to idw isnt possible... do I have to open all assemblies and place views one by one?
JelteDeJong
Im not sure what you exactly need but you can try this.
' Replace with your own path
Dim searchPath As String = "D:\forum\"
' Make sure it exits
Dim writeDirectory As String = "D:\forum\output\"
' if the wrong template is used then provide the corect template path
Dim templateFileName As String = ThisApplication.FileManager.GetTemplateFile(
    DocumentTypeEnum.kDrawingDocumentObject)
Dim oTg As TransientGeometry = ThisApplication.TransientGeometry
Dim searchDir As IO.DirectoryInfo = New IO.DirectoryInfo(searchPath)
Try
    For Each fileInfo As IO.FileInfo In searchDir.GetFiles("*.iam")
        Dim assembly As Document = ThisApplication.Documents.Open(fileInfo.FullName, True)
        Dim doc As DrawingDocument = ThisApplication.Documents.Add(
            DocumentTypeEnum.kDrawingDocumentObject, templateFileName)
        Dim sheet As Sheet = doc.ActiveSheet
        Dim center As Point2d = oTg.CreatePoint2d(sheet.Width / 2, sheet.Height / 2)
        Dim view As DrawingView = sheet.DrawingViews.AddBaseView(
            assembly,
            oTg.CreatePoint2d(0, 0),
            1,
            ViewOrientationTypeEnum.kIsoTopLeftViewOrientation,
            DrawingViewStyleEnum.kShadedDrawingViewStyle)
        Dim scaleX = sheet.Width / view.Width
        Dim scaleY = sheet.Height / view.Width
        If (scaleX < scaleY) Then
            view.Scale = scaleX
        Else
            view.Scale = scaleY
        End If
        view.Center = center
        assembly.Close(True)
        Dim newFileName As String = IO.Path.Combine(
            writeDirectory, IO.Path.ChangeExtension(fileInfo.Name, "idw"))
        doc.SaveAs(newFileName, True)
    Next
Catch ex As Exception
    MsgBox(ex.Message)
End Try
ThisApplication.SilentOperation = False
Jelte de Jong
Blog: hjalte.nl - github.com
