Insert iLogic Assembly Fail
RogerTheShrubber
RogerTheShrubber
My first iLogic assembly.  Thanks to all for posting on the forms and Curtis W. for 'Mastering Inventor.'
I created a properly functioning iLogic assembly.  I am having issues using the 'Place iLogic Component' to use it in another assembly.   Using 'Place iLogic Component' creates the files in the project's Workspace, but the iLogic assembly is not placed in the target assembly. Please see the attached screencast which hopefully shows everything needed to diagnose.
chandra.shekar.g
Autodesk Support
Autodesk Support
@RogerTheShrubber,
Can you please provide cylindrical generator.iam to test? Please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
RogerTheShrubber
Problem solved.  I had an iLogic rule triggered by opening document that looked to change the LOD of parts in the assembly.  For whatever reason, suppressing the rule caused this issue to go away.  I can send the files if you are still interested in looking at this behavior.
