Insert ACAD File into Sketch API
Hi all,
I've been doing some searching on these forums for an API to insert an ACAD file into a sketch.
Is there an API call to do this? I found that I can use the command manager with PostPrivateEvent :
oCmdMgr.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, sFileName)
oCmdMgr.ControlDefinitions("SketchInsertAutoCADFileCmd").Execute
It works great for my purpose BUT it doesn't auto constrain the endpoints, which is essential as I need to extrude /sweep after it has inserted.
There is an option to constrain end points when you manually do the import, but the command manager mustn't have anyaccess to options ?
So two questions I guess
1. Is there an API to insert an ACAD file into a sketch ?
2. If there isn't, is there another way to constrain the end points to make a loop after the insert?
Tom
ps. I'm using Inventor 2011
Well after a lot of trial and error I've finally got things working, I couldn't find an API for the ACAD insert so I had to stick with the CommandManager as above.
This is the code I'm using to constrain the endpoints in the sketch (uses the .Merge() method) :
Dim StartCounter As Integer
		Dim PointItemMaster As SketchPoint
		Dim PointItemClient As SketchPoint
		For Each PointItemMaster In oSketch.SketchPoints
			StartCounter = 0
			For Each PointItemClient In oSketch.SketchPoints
				If Round(PointItemClient.Geometry.x,4) = Round(PointItemMaster.Geometry.x,4) And Round(PointItemClient.Geometry.y,4) = Round(PointItemMaster.Geometry.y,4) Then
					StartCounter = StartCounter + 1
					If StartCounter = 2 Then
						PointItemMaster.Merge(PointItemClient)
						StartCounter = 0
						Exit For
					End If
				End If
			Next PointItemClient
		Next PointItemMaster
When I dumped out all the XY's for the sketch entities I found that for whatever reason some of them were out by 0.000000000000001 - hence the Round() on the sketchpoints (4 decimal places is plenty accurate for what I'm doing)
Thought I'd post in case someone has the same problem in the future.
Tom
