Insert a note for a threaded hole in a drawing in Inventor using C# / VBA
vincenzobYFDD6
vincenzobYFDD6
Good morning, is there a way to insert a thread note in Inventor via API? See image.sd
NachoShaw
Yes its possible.
this code assumes you have the note selected
    Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
    If oDoc.SelectSet.Count <> 1 Then
        MsgBox ("A thread note must be selected.")
        Exit Sub
    If Not TypeOf oDoc.SelectSet(1) Is HoleThreadNote Then
        Exit Sub
	Dim oThreadNote As HoleThreadNote = CType(oDoc.SelectSet(1), HoleThreadNote)
	oThreadNote.FormattedHoleThreadNote = "Thread Note Value Changed"
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
and this one creates a thread note. Again, it assumes the thread is selected.
	Dim oApp As Inventor.Application = ThisApplication
    Dim oDoc As DrawingDocument = oApp.ActiveDocument
        MsgBox ("A single thread edge must be selected.")
        Exit Sub
    If Not TypeOf oDoc.SelectSet(1) Is DrawingCurveSegment Then
        MsgBox ("A thread edge must be selected.")
        Exit Sub
    Dim oThreadEdge As DrawingCurve = oDoc.SelectSet(1).Parent
    If Not (oThreadEdge.EdgeType = kThreadEdge) Then
        Exit Sub
    Dim oPosition As Point2d = oApp.TransientGeometry.CreatePoint2d(22, 21)
    Dim oThreadNote As HoleThreadNote = oDoc.ActiveSheet.DrawingNotes.HoleThreadNotes.Add(oPosition, oThreadEdge)
Nacho
JelteDeJong
Something you might want to have a look at. In the blog post "Automatically generate hole position dimensions" I show how you can add notes to all your holes, automatically to your drawing
Jelte de Jong
Blog: hjalte.nl - github.com
vincenzobYFDD6
Sure, JelteDeJong, I had already found your solution. Very, very valid and helpful.
