BoundaryPatch with open 3D-profile
frank_willing
frank_willing
 I want to create a boundary Patch with a 3D-line , that is connected to 2splines.
With this I want to create a boudary patch:
- manually this functiions in Inventor: I choose the 3d Line as boundaryloop then the 2 splines as rails. Inventor creates the boundary patch as desired.
Now I tried to do this programmatically:
- The Guide-Rails are no Problem
- But Inventor does not accept the 3d Line as boundaryloop, I already tried to use it as path, collection or profile3d.
Attached you will find the ipt.
Can somebody help?
Regards Frank
frank_willing
I just tried to buid it again in VBA:
- I "stole" the patchloop object from the existing(manual built) BoundaryPatch
- then I tried to rebuild it with VBA
- But the code crashes in the line I add the patch loop to the BoundaryPatchDefinition
I there any way to built the BounderyPatch or another way to create a Surface fitting to the Splines an the 3DLines?
Public Sub test()
Set obj = ThisApplication.ActiveDocument
Dim opatch As BoundaryPatchFeature
Set opatch = obj.ComponentDefinition.features.BoundaryPatchFeatures.Item(1)
Dim Patchloop As BoundaryPatchLoop
Set Patchloop = opatch.Definition.BoundaryPatchLoops.Item(1)
Dim Spline1 As SketchSpline3D
Dim Spline2 As SketchSpline3D
Dim osketch As Sketch3D
Set osketch = obj.ComponentDefinition.Sketches3D.Item(1)
Set Spline1 = osketch.SketchSplines3D.Item(1)
Set Spline2 = osketch.SketchSplines3D.Item(2)
Dim BoundPatchDef As BoundaryPatchDefinition
Set BoundPatchDef = obj.ComponentDefinition.features.BoundaryPatchFeatures.CreateBoundaryPatchDefinition
Call BoundPatchDef.GuideRails.Add(Spline1)
Call BoundPatchDef.GuideRails.Add(Spline2)
Call BoundPatchDef.BoundaryPatchLoops.Add(Patchloop)
Dim Kurvenfläche2 As BoundaryPatchFeature
Kurvenfläche2 = odoc.ComponentDefinition.features.BoundaryPatchFeatures.Add(BoundPatchDef)
End Sub
Thanks and regards Frank
frank_willing
Hello together,
 I solved the problem in another way:
- I Closed the 3Dsplines
- I put the outer-spline to a collection1 and the innerspline to a second collection
- then I added these collections as boundaryloops and created the boundarypatch
Dim Spline_innen As SketchSpline3D
Spline_innen = drei_D_skizze.SketchSplines3D.Add(Punkte_innen)
Spline_innen.Closed = True
Dim Spline_aussen As SketchSpline3D
Spline_aussen = drei_D_skizze.SketchSplines3D.Add(Punkte_aussen)
Spline_aussen.Closed = True
drei_D_skizze.ExitEdit()
objColl1.Add(Spline_aussen)
objColl2.Add(Spline_innen)
BoundPatchDef.BoundaryPatchLoops.Add(objColl1)
BoundPatchDef.BoundaryPatchLoops.Add(objColl2)
Dim Kurvenfläche1 As BoundaryPatchFeature
Kurvenfläche1 = oDoc.ComponentDefinition.Features.BoundaryPatchFeatures.Add(BoundPatchDef)
regards Frank
