InputListBox if cancel button pressed abort.
K.TRYFONIDIS
K.TRYFONIDIS
Hello all,
So i have this simple Array list that covers my needs.
And after this one there is another one and another one untill i populate all the properties i need.
My problem is that i want somehow to go to end of the script or abort "the mission" if the user clicks the X button ( cancel button) at the top right corner. Maybe show a message prompt like, "do you want to abort?"
Now i have to click X at all forms to end the script.
Is there a simple command like If cancel.button pressed go to [label] or go to end of script ?
Thanks a lot in advance.
Dim oValueList1 As New ArrayList
	oValueList1.Add("option1")
	oValueList1.Add("option2")
	oValueList1.Add("option3")
Dim oValue1 As String = InputListBox("Choose Material", oValueList1)
iProperties.Value("Custom", "Materialtype") = oValue1
WCrihfield
Absolutely.  There are usually a few ways to handle this, depending on your needs.  Here is one example.
If String.IsNullOrEmpty(oValue1) Then
	If MsgBox("Do you want to abort?", vbYesNo + vbQuestion, "Abort?") = vbYes Then Exit Sub
End If
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
Or, if you had not pre-defined the 'oValue1' variable as a String, and since you had not really defined that Type of objects in the ArrayList, the value returned from the InputListBox would be a generic Object.  So, you could check if the un-defined variable that holds the result 'Is Nothing'.
Wesley Crihfield
K.TRYFONIDIS
Ok this is very clever ! Thank you! 🙂
