Input list box
Input list box
tomislav.peran
Input list box
tomislav.peran
In order to use Select Case option in the code, firstly I need to choose which case I wish to use.
d0 = InputListBox("Prompt", MultiValue.List("d0"), d0, Title := "Title", ListName := "List")
I use a user parameter to make a list of options/cases for that.
However, these user parameters have sometimes no use outside a single rule.
Would it be possible to make a local multivalue parameter that only exists within that rule and not as a user rule in
the document?
Tom
WCrihfield
Hi @tomislav.peran.  You could make your own list within the rule itself, if all you need is some options in a list to be able to use an InputListBox.  Below is a simple example of this:
Dim oOptions As New List(Of String)
oOptions.Add("Option 1")
oOptions.Add("Option 2")
oOptions.Add("Option 3")
oOptions.Add("Option 4")
Dim oChosenOption As String = InputListBox("Choose One.", oOptions, "", "OPTIONS", "List of Options")
MsgBox("You chose '" & oChosenOption & "' from the list.", vbInformation, "iLogic")
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
tomislav.peran
Hi WCrihfield,
Ah great. I really do not want to have user parameters for cases used in a single rule.
Thank you a lot!
Tom
