Input box - Multiple inputs
Hey there
Is it possible to make an inputbox via ilogic where I can change multiple values at once?
I want to fill in my drawing header, and I want to enter it manually
My code this far looks like this:
EmneThing = iProperties.Value("Project", "Description")
iProperties.Value("Project", "Description") = InputBox("Emne", "Emne", EmneThing)
While iProperties.Value("Project", "Description") = ""
End While
DelAfThing = iProperties.Value("Summary", "Subject")
iProperties.Value("Summary", "Subject") = InputBox("Del af", "Del af", DelAfThing)
While iProperties.Value("Summary", "Subject") = ""
End While
RevisionThing = iProperties.Value("Project", "Revision Number")
iProperties.Value("Project", "Revision number") = InputBox("Revision", "Revision", RevisionThing)
While iProperties.Value("Project", "Revision Number") = ""
End While
GodkendtThing = iProperties.Value ("Project", "Authority")
iProperties.Value("Project", "Authority") = InputBox("Godkendt af", "Godkendt af", GodkendtThing)
While iProperties.Value("Project", "Authority") = ""
End While
InventorVb.DocumentUpdate()
It causes four boxes in a row, whereas I would prefer one - If possible
Hello Yannick,
isn´t it possible to make a form for filling all parameters?
The form can be fired with the command:
iLogicForm.Show()
Greetz
It is possible, yes - I couldn't get it to fire a global form, though.
Is there anything special I have to do to make it fire a global form?
Yes, with:
iLogicForm.ShowGlobal("FormName")
c.bloedorn
Is there a different option these days?
I want to trigger my code automatically, but if I were to open a form via my code, the code wouldn't "pause" like it does for input boxes.
Does anyone have a solution for this?
