incremental file names
michielXWZ7U
michielXWZ7U
Hi guys, i am using some code that will save my file in the name of the following
"MP-001-plaat " & length & "X" & width & "X" & Thickness & "mm"
 In the line the ''001'' inside ''MP-001-plaat'' represents the part number in the folder of the project. Inside the folder i arrange all the parts incremental. So every part starts with ''MP-00n' with n+1 for every new part.
Anyone knows how i can adjust the code that every new created parts checks the numbers in the folder location, and adds the next number to the next saved part.
The full code that i am using is:
Dim oDoc As Inventor.Document = ThisApplication.ActiveDocument
Dim FName As String = oDoc.FullFileName
Dim FNP As Integer = InStrRev(FName, "\", -1)
Dim oPath As String = Left(FName, FNP)
Dim oNewName As String = "MP-001-plaat " & lengte & "X" & breedte & "X" & Thickness & "mm"
' If the user closes the input box, then stop the function
'If oNewName = vbNullString Then Exit Sub
Dim oType As String
Select Case oDoc.DocumentType
Case kPartDocumentObject:     oType = ".ipt"
Case kAssemblyDocumentObject: oType = ".iam"
Case kDrawingDocumentObject:  oType = ".idw"
End Select
oDoc.SaveAs(oPath & oNewName & oType, True)
 With kind regards, michiel
vpeuvion
Here is a piece of code that displays all the filenames present in the folder. It remains to find the largest number and thus give the next number to your part. I hope this can help you move forward.
Vincent.
Dim fileEntries As String() = System.IO.Directory.GetFiles(oPath)
For Each fileName As String In fileEntries
MessageBox.Show(fileName)
Next
WCrihfield
Hi @michielXWZ7U.  I don't know where/how your "lengte", "breedte", or "Thickness" terms are being defined in your code, but I assumed that they may be either the names of local parameters or simply defined above this block of code somewhere.  Here is something you can try for your naming scenario.  It makes use of the same GetFiles method mentioned in @vpeuvion post, but also follows through with the rest of the code that I assume you are looking for.  See if this works out for your needs.  There is a lot of stuff in there, so if you have any questions, feel free to ask them.
oPath = System.IO.Path.GetDirectoryName(oDoc.FullFileName)
oDirS = System.IO.Path.DirectorySeparatorChar
oExt = System.IO.Path.GetExtension(oDoc.FullFileName)
Dim oPNTemp As String = ""
Dim oPN As String = ""
oFileNames = System.IO.Directory.GetFiles(oPath, "*" & oExt, System.IO.SearchOption.TopDirectoryOnly )
For Each oFileName In oFileNames
	oName = System.IO.Path.GetFileNameWithoutExtension(oFileName)
	If oName.StartsWith("MP-") And oName.Contains("-plaat ") Then
		oPNTemp = oName.Split("-")(1)
		If String.IsNullOrEmpty(oPN) Then oPN = oPNTemp
		If CInt(oPNTemp) > CInt(oPN) Then oPN = oPNTemp
Next
oPN = Strings.Format(CStr(CInt(oPN) + 1), "000")
Dim oNewName As String = "MP-" & oPN & "-plaat " & lengte & "X" & breedte & "X" & Thickness & "mm"
oDoc.SaveAs(oPath & oDirS & oNewName & oExt, True)
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
