Custom prop expression formula
JoAntt
JoAntt
Can i some how in Custom propertys expression get the real Mass, like
<=formatTheMassToKg(Mass)>
I dont want i logic or anything else.
And is it possible to format 123,13232mm to 123,2mm or 123,2?
theo.bot
You can only set the mass unit in the document settings. But for rounding the mass value I don't think there is a way without ilogic.
An exported parameter can be formatted. After setting a parameter to export, RMB on the parameter and choose "custom format". In this dialog you can define your output that is shown in the iproperties.
b.mccarthy
Just wondering why the "Custom Property Format..." option is only available for specific parameters:
Both parameters are inches.
Thank you.
A.Acheson
The Custom Property Format button becomes available when you check the parameter for export to iproperties.
Regards
Alan
b.mccarthy
Thank you. I have never used it. Learn a little more about the software every day...
