Include User Parameters in a Derived Part
MJH_
MJH_
I'm currently trying to automate a way of including only the User Parameters in a derived part.
oDoc = ThisApplication.ActiveDocument
If oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Count > 0
Dim oDerComp As DerivedPartComponent = oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents(1)
Dim oDerDef As DerivedPartDefinition = oDerComp.Definition
oDerDef.IncludeAllParameters = True
oDerDef.UseColorOverridesFromSource = False
oDerComp.Definition = oDerDef
The above code almost works as intended, however it includes all parameters in the Derived Part (due to the line oDerDef.IncludeAllParameters).
Is there a way to include only the User Parameters?
Michael.Navara
You need to include all parameters and exclude non user parameters. And also you can do another check.
Dim activePart As PartDocument = ThisDoc.Document
'Create new part derived from this one
Dim newPart As PartDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject)
Dim derivedPartDef As DerivedPartDefinition = newPart.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(activePart.FullFileName)
'Include all parameters
derivedPartDef.IncludeAllParameters = True
'Exclude non user parameters
For Each entity As DerivedPartEntity In derivedPartDef.Parameters
	Dim userParam As UserParameter
	userParam = TryCast(entity.ReferencedEntity, UserParameter)
	If userParam Is Nothing Then
		entity.IncludeEntity = False
		continue for
'	'Include only parameters which name starts with "Incl"
'	If Not userParam.Name.StartsWith("Incl") Then
'		entity.IncludeEntity = False
'	End If
Next
newPart.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(derivedPartDef)
newPart.Activate()
MJH_
Thanks for the response but I may not have fully explained what I'm after. If I create a new parameter in a skeleton, I then have to go in to the part I've created, right-click the derived skeleton and include the new parameter. I'm trying to automate this process and create a Global Form button which will execute the code within existing parts to update my derived user parameters. The aim is to just update the existing User Parameters that have been pulled through from the skeleton.
MJH_
After a bit of plugging and playing I've managed to work it out.
For Each entity As DerivedPartEntity In oDerDef.Parameters
	Continue For
Next
