In IDW how to delete all parameter?
omvcilindri
omvcilindri
hi everybody
I need help, I would like to delete all parameter in idw file existing, is it possible whit ilogic?
tanks to all
Curtis_Waguespack
Hi @omvcilindri
I had this example on hand.
I hope this helps.
Curtis
oRUSure = MessageBox.Show("Are you sure you want to delete all of the" & vbLf & _
"parameters in this file?", "iLogic", MessageBoxButtons.YesNo, MessageBoxIcon.Question)
If oRUSure = vbNo Then Return 'exit rule
oApp = ThisApplication
Call oApp.TransactionManager.StartTransaction(ThisDoc.Document, "Delete All Parameters")
oDoc = ThisApplication.ActiveDocument
oParams = oDoc.Parameters
'look at each parameter
Do Until oParams.Count = 0
	For Each oParam In oParams
		'delete the Parameter
		Try : oParam.Delete : Catch : End Try
	Next
Loop
oApp.TransactionManager.EndTransaction
omvcilindri
Amazing
great job
thanks
