Get Unit Abbreviations
Noah.ClarkX5FEF
Message 1 of 19
Noah.ClarkX5FEF
Hi there,
I know there is a way to get the default display units such as inch, foot, centimeter in inventor but is there a way to get the default display abbreviated units like in, ft, cm?  It would be nicer than having to code out the case statement for each unit type to get its abbreviation.  I would find it odd if there wasn't because you can use the abbreviated forms in some of the Units Of Measure procedures/functions.
Accepted solutions (4)
Replies (18)
Message 2 of 19
WCrihfield
Are you maybe thinking of this method:  UnitsOfMeasure.GetStringFromType()?  There are also lots of other related methods and properties (tools) under the UnitsOfMeasure object.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 19
Noah.ClarkX5FEF
Sadly no.   UnitsOfMeasure.GetStringFromType() gets the full Length unit type not the type abbreviation.  I know how to do get a string "inch".  I would like to get a string "in".
Message 4 of 19
WCrihfield
For the most part, you will not find unit abbreviations available in a list for many of the units used for area, volume, & density.  There may be a few, but if you need something specific, you pretty much just have to create it yourself.  Most of the time its just as simple as putting a single space between the unit abbreviations to specify the units for those types of measurements.  For instance, you can use "in in" or "in^2" for square inches area, and "in in in" or "in^3" for inches cubed volume, and so on.
Wesley Crihfield
Message 5 of 19
Curtis_Waguespack
Hi @Noah.ClarkX5FEF
Give this a try.
I hope this helps.
Curtis
Edit to add:
Just noticed you tagged this VBA, so I figured I better check to make sure it didn't return something different in VBA for some reason, but it doesn't. Here is the same for VBA:
    Dim oUOM As UnitsOfMeasure
    Set oUOM = ThisApplication.ActiveDocument.UnitsOfMeasure
    oLenUnits = oUOM.GetStringFromType(UnitsTypeEnum.kDefaultDisplayLengthUnits)
    MsgBox (oLenUnits)
iLogic version:
	oUOM = ThisDoc.Document.UnitsOfMeasure
	MsgBox(oLenUnits,, "iLogic")
Message 6 of 19
Noah.ClarkX5FEF
wait how does that work?  every time I use
I only get "inch".
Message 7 of 19
WCrihfield
Good point.  It seems like I've seen something like this before, but don't recall where.  I do know that when checking the value of Parameter.Units property, you usually get the abbreviated version of the units string.  And you usually see (and can retrieve) the Expression of a parameter, it will contain the abbreviated version of the units string.  And when viewing the Physical tab of the iProperties dialog, you see the abbreviated units shown after the numerical values.  The Autodesk programmers must be using some sort of behind the scenes routine to generate those abbreviated Strings for internal use.  It would certainly be a pain in the @'s to have to find or create a parameter then retrieve its units string each time though.
Wesley Crihfield
Message 8 of 19
WCrihfield
If using the few "kDefaultDisplayLengthUnits" type specifications, you can only get the units currently set as default.  What about other non-default units abbreviations.  Would you then have to change your default units first, then get the abbreviated version of it using that method, then switch your units back each time?  That would certainly not be ideal.  I'm thinking that a custom Function is likely needed just for returning the abbreviated versions of all the various units we might be working with, because I don't know of another readily available way.
Wesley Crihfield
Message 9 of 19
WCrihfield
You could also just create your own alternate Enum to reference (Link1, Link2), that would return the abbreviated versions of the unit names, instead of the full unit names.  You could even have it in another external iLogic rule that was set to StraightVB, then reference that rule using the AddVbFile system, if needed.
Wesley Crihfield
Message 10 of 19
Curtis_Waguespack
I only get "inch".
hmmm, I'm not sure. I did a couple quick checks to see if I could think of a setting, but didn't see anything.
Message 11 of 19
Noah.ClarkX5FEF
Ok so my code is different then yours:
My code:
Dim eLengthUnit As UnitsTypeEnum
eLengthUnit = oUOM.LengthUnits
DocUnits = oUOM.GetStringFromType(eLengthUnit)
 The difference is I used length units vs you used display units.  For some reason the display units show as the abbreviated form.  I thought they were the same but I guess they are different.
Message 12 of 19
Maxim-CADman77
I wish this discussion ends with workflow for getting abbreviation for any (not just default) unit (i mean something better than @WCrihfield's idea to change the default unit and then undo the action).
For me select case seems too clumsy from the point of developing global solutions (with indefinite Inventor UI-language).
PS:
I don't understand why three messages are marked as answers (for me second and third are just repeatings of the Curtis's answer).
Please vote for Inventor-Idea Text Search within Option Names
Message 13 of 19
Maxim-CADman77
I wonder whether @JelteDeJong knows the solution for this?
Message 14 of 19
JelteDeJong
I could not find a method for getting the abbreviations of units. But there is another workaround. Have a look at this:
Dim doc As PartDocument = ThisDoc.Document
Dim uom As UnitsOfMeasure = doc.UnitsOfMeasure
Dim tempString = uom.GetStringFromValue(123, UnitsTypeEnum.kKilogramMassUnits)
Dim unitAbbreviation = tempString.Split(" ")(1)
MsgBox(unitAbbreviation)
the value string uses the format "<value> <abbreviation of the units>" So if you create a "value string" and give some random number.  And split on the space between the random number and the "abbreviation of the units", and you get an array. The 2e element in the array is your abbreviation.
That is the best I could think of but still a bit of a hack
Edit:
Changed code to give a full example
Jelte de Jong
Blog: hjalte.nl - github.com
Message 15 of 19
Maxim-CADman77
@JelteDeJong  IMHO this is more elegant than anything that was mentioned above.
If I were the thread host I would definitely mark it a solution. Many thanks!
Message 16 of 19
Maxim-CADman77
@JelteDeJong
Yet this trick doesn't provide ability to get local "Each" abbreviation:
Message 17 of 19
Maxim-CADman77
@JelteDeJong
Seems like units abbreviation (at least LengthUnit) returned by the trick you've suggested depends on the localization of Inventor the document was created (or may be saved) with ... which is not what me expected.
I then tried to use UnitsOfMeasure property of Application instead of Document's property but got an exception (see the code-snippet below).
logger.info("1:" & UnitsTypeEnum.kDefaultDisplayLengthUnits) ' 11260
oUOM = ThisDoc.Document.UnitsOfMeasure ' +
logger.info("2:" & oUOM.GetStringFromValue(1, UnitsTypeEnum.kDefaultDisplayLengthUnits).Split(" ")(1))
oUOM = ThisApplication.UnitsOfMeasure
logger.info("3:" & oUOM.GetStringFromValue(1, UnitsTypeEnum.kDefaultDisplayLengthUnits).Split(" ")(1)) ' Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Thus I'd like to know:
1. What I'm missing regarding the exception?
2. How do I get Unit Abbreviations relevant to current Inventor localization?
Message 18 of 19
WCrihfield
Interesting issue.  I too got an error with that code.  I was able to get rid of that error by using a different method (GetPriciseStringFromValue vs GetStringFromValue).  I don't know why that would make a difference though.
Dim oUOM As Inventor.UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
Logger.Info("1:  " & oUOM.GetPreciseStringFromValue(1, UnitsTypeEnum.kInchLengthUnits).Split()(1))
Logger.Info("2:  " & oUOM.GetPreciseStringFromValue(1, UnitsTypeEnum.kInchLengthUnits).Split()(1))
  I do see that there is a method called "GetLocaleCorrectedExpression", but the documentation for it sort of suggests that it may only correct decimal place character changes.  It does not mention units string abbreviation conversion.  The only 'localization' related tool I have seen within iLogic or Inventor API is a tool I found maybe a year ago, but it seems to be specific to the names of ModelStates, not just general verbiage.
Dim oMSName As String = "Master"
Dim oMSNUtils As New Autodesk.iLogic.Runtime.ModelStateNameUtils
Dim sLocalizedName As String = oMSNUtils.GetLocalizedName(oMSName)
MsgBox("The 'Localized' version of " & oMSName & " is:  " & sLocalizedName, vbInformation, "iLogic")
Wesley Crihfield
Message 19 of 19
Maxim-CADman77
@WCrihfield
Using GetPriciseStringFromValue and Application's UnitsOfMeasure property I still get English LengthUnits Abbreviation while using non-English Inventor localization ... which is not what I need.
