IMPORT SHEET METAL UNFOLD RULES WITH VBA
nicolamora
nicolamora
I have many old parts with the wrong unfold sheet metal unfold rules.
Is it possible to import an unfold .styxml file with a vba macro?
Ralf_Krieg
Hello
"Writing in CAPITAL LETTERS or constant bold type is not only considered unsightly, but is usually interpreted as aggressive shouting and should therefore be avoided."
Save the actual/correct Sheet Metal Unfold to your style library. Thereafter it is available in every sheet metal part and can be used.
R. Krieg
RKW Solutions
www.rkw-solutions.com
nicolamora
Hello, and thanks for your reply.
Sorry if I used capital letters, but I don't usually ask questions on forums so I don't know the "meaning" of everything...
However, I would personally pay more attention on the subject of the question instead of the useless minor details.
As I know, since 2021 it was not possible import .styxml file with VBA, and I was wondering if this was implemented with the new Inventor version.
Now, my workaround of this is: when a file is open a VBA program check if the unfold rule is current, if not, it give you a message and a new unfold rule is created locally.
This works great, but the only downside is if a parameter is changed in the template, also the program must be changed.
Thanks, Nicola
Ralf_Krieg
Hello
An import of styxml is not implemented yet.
Why don't you use the style library? You can insert and edit every style and unfold method at a central place. You can compare local styles with library and update if necessary. Or if unfold method don't exist in file, use ConvertToLocal method to create a local copy of library style in document.
R. Krieg
RKW Solutions
