Import .rvt into Assembly with API
autodeskuser58
Message 1 of 1
autodeskuser58
Hi, I have a task to upload a cheat file to the build. I found a simple example for iLogic in the help and it works when running in Inventor. But when I do the same thing, it's only with an external request that I get an error, maybe I'm not connecting any addins or something like that. Could you please suggest solutions to the problem
name_RVT = System.IO.Path.GetFileNameWithoutExtension(filePathRVT);
if (invApp == null)
Console.WriteLine("Error: Application");
return;
AssemblyDocument assemDoc = (AssemblyDocument)invApp.Documents.Add(Inventor.DocumentTypeEnum.kAssemblyDocumentObject, "", true);
Thread.Sleep(60 * 1000);
ImportedRVTComponentDefinition importedRvtDef = (ImportedRVTComponentDefinition)assemDoc.ComponentDefinition.ImportedComponents.CreateDefinition(filePathRVT);
importedRvtDef.Imported3DView = "{3D}";
importedRvtDef.ImportedAssemblyOrganizationType = ImportedAssemblyOrganizationTypeEnum.kImportedAsAssembly;
ImportedComponentDefinition baseDef = (ImportedComponentDefinition)importedRvtDef;
ImportedRVTComponent rvtComp = (ImportedRVTComponent)assemDoc.ComponentDefinition.ImportedComponents.Add(baseDef);
var savePath = System.IO.Path.Combine(defaultPath, name_RVT + ".iam");
assemDoc.Update();
assemDoc.SaveAs(savePath, false);
The error is in this line: ImportedRVTComponentDefinition importedRvtDef = (ImportedRVTComponentDefinition)assemDoc.ComponentDefinition.ImportedComponents.CreateDefinition(filePathRVT); Error: "Unidentified error (0x80004005 (E_FAIL))"
Replies (0)
