Import iProperties From Excel to Specific Part in .iam File
Message 1 of 1
Hello, I am still new to iLogic and I was wondering if this is even possible. I have created a rule which allows me to fill out iProperties of whatever .ipt I have open from an excel fill. However, what I want is to apply a rule like this to a .iam  which would allow me enter a specific part number, retrieve the information about that part number from the columns in excel,  and then have the iproperties to that specific part within the assembly be filled out.  I will attach the code I have that works on an .ipt file
	'Define excel file variables
Dim BOM_path As String = "C:\LSE Vault\Data\iProperties_new.xlsx"
Dim osheetbom As String = "Sheet1"
	'ensure correct file is active
xlApp = CreateObject("Excel.Application")
xlApp.Visible = True
xlWorkbook = xlApp.Workbooks.Open(bom_path)
xlWorksheet = xlWorkbook.Worksheets.Item(osheetbom)
	'prompt user for part number
part_number = InputBox("Plese enter the part number", "Get Data")
	'Cancel test
If part_number = "" Then
	MsgBox("Please enter a Valid Part Number", , "No Part Numbered Entered")
	Return
End If
	'declares conditional statement // searches through part numbers
Dim j As Integer = 1
Line1 :
oTest = xlWorksheet.Range("A" & j).Value
If oTest <> "" Then
	j = j + 1
	GoTo Line1
End If
	'locates entered part number and pulls information
For row = 2 To j
	If xlWorksheet.Range("A" & Row).Value = part_number Then
		iProperties.Value("Project", "Part Number") = xlWorksheet.Range("A" & Row).Value
		iProperties.Value("Project", "Description") = xlWorksheet.Range("B" & Row).Value
		iProperties.Value("Project", "Project") = xlWorksheet.Range("C" & Row).Value
		iProperties.Value("Summary", "Title") = xlWorksheet.Range("D" & Row).Value
		MessageBox.Show("All properties have been applied", "Success")
	End If
Next
xlWorkbook.Close (True)
xlApp.Quit
Replies (0)
