Import in an .ipt using iLogic
peterjoachim
peterjoachim
What I'm trying to do is create a .ipt template that, when creating a new .ipt using the template, will automagically open the Manage/Insert/Import command (see screenshot) along with a custom form. The form part is easy. I just haven't been able to figure out the Import part. Is this possible?
WCrihfield
I think the command you are looking for is "AppImportFileCmd".
It is used like this.
ThisApplication.CommandManager.ControlDefinitions.Item("AppImportFileCmd").Execute
 What I would do is put this into an iLogic rule.  Then on the Manage tab / iLogic panel (within the template file), click on Event Triggers, and add that rule under the New Document event.
It's probably best that this rule be an external rule, just so you don't end up with tons of part files that all have variations of this rule in them.  And if you need to change something, you can do it in the one place, instead of a whole lot of places.
Wesley Crihfield
(Not an Autodesk Employee)
peterjoachim
That's exactly what I'm looking for. But when I just tried that it's failing to complete the command. See screencast. Anymore ideas?
https://www.screencast.com/t/vx7K24uCqgIx
JhoelForshav
Hi @peterjoachim
Executing asynchronously made the difference for me.
Try it like this instead:
ThisApplication.CommandManager.ControlDefinitions.Item("AppImportFileCmd").Execute2(False)
In the future, if you want to find the name of a controldefinition to execute this way, "AppImportFileCmd" for example, I've created a tool for this that you can run as an ilogic rule:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/simplecontent/content/ilogic-tool...
WCrihfield
Nice tool!
I was using a few simpler rules.  One that writes out a somewhat detailed listing of each Command to a text file.  One that I can enter a string (keyword I'm looking for) and it loops through all control definitions to see if their DisplayName 'contained' my input string, and would return the single or list of command names that matched that criteria.  Among others.  But your rule works more like a simplified 'record macro' tool.
Wesley Crihfield
JhoelForshav
Thank you @WCrihfield
I actually used to just google it. The problem with that was that sometimes the command name i found had been replaced. So I wrote this to make sure i always get the correct and up-to-date name 🙂
peterjoachim
That worked great. Also.. that is a sweet tool. Thanks.
