Import iLogic Configuration File
Is it possible to write some ilogic code to automatically import an ilogic configuration .xml file. I don't want to manually add external rule directories to each machine on the network. You can do it manually in this screen.
Thanks! I can drop the xml file there, but is it possible to write code to import the xml file on its own?
I'm looking as well for an option to import these settings in Inventor by its own.
No one any idea how to solve this?
I still haven't received a solution on this but will continue to investigate and update this thread when I figure it out.
