Import a sheet metal style in iLogic
I was wondering if you anyone could help me with importing a sheet metal style (STYLENAME.styxml) into a sheet metal part.
I would like to automatically import the style using an iLogic script.
Thanks!
Any idea would be appreciated!
So far I have gone to this solution:
1- Copy an existing sheet metal style
2- Modify the parameters to my own style
(Using the code provided in the help- Attched here)
The problem is the materials. I have a custom aluminum in my original style that I can't create/import. Is tehre a way to import or mody an existing material in iLogic code?
I have got ths for material creation:
Sub Main
CreateMaterial
End Sub
Public Sub CreateMaterial()
    ' Set a reference to the part document.
    ' This assumes a part document is active.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    ' Create a new material.
    Dim oNewMaterial As Material
    Set oNewMaterial = oPartDoc.Materials.Add("My Material", 11.37)
    ' Define the other properties of the material
    oNewMaterial.LinearExpansion = 5.73
    oNewMaterial.PoissonsRatio = 0.38
    ' Arbitrarily assigns the first render style in the render styles collection.
    oNewMaterial.RenderStyle = oPartDoc.RenderStyles.Item(1)
    oNewMaterial.SpecificHeat = 124.3
    oNewMaterial.ThermalConductivity = 310.2
    oNewMaterial.UltimateTensileStrength = 210.45
    oNewMaterial.YieldStrength = 185.5
    oNewMaterial.YoungsModulus = 76.37
End Sub
 But importing the styxml file would have been much easier!
Any ideas? Please!
xiaodong_liang
Autodesk Support
Autodesk Support
Hi rc3ng,
The loading/importing styxml is still a wish which has not been implemented. Sorry if this is bad news for you. The wish number is: 667891.
Thanks for your tip! Now I can stop wondering around to find a command that does not exist yet 🙂
mrattray
Is this true of all .styxml's, or only sheet metal styles? I'm trying to import a custom unfold style via iLogic.
Mike (not Matt) Rattray
VdVeek
Xiaodong Liang, i can't find this Wish number in the Ideastation, can you provide a link.
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
