Implement a condition
ch_giacomo
ch_giacomo
Good morning everyone.
I have this piece of code and would like to implement a condition.
Basically this part should work like this:
if the rule runs in an .IPT file have this run
if the rule runs in an .IAM file ignore the part
Do you think it is possible?
'If "MaterialType" does not exist, create it and set up as above
oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
oParameter = oMyParameter.AddByValue("MaterialType", iProperties.Material, UnitsTypeEnum.kTextUnits)
MultiValue.List("MaterialType") = iProperties.Materials
InventorVb.DocumentUpdate(False)
iProperties.Material = InputListBox("Select a Material", MultiValue.List("MaterialType"), parameter("MaterialType"), Title := "iProperty Helper", ListName := "UNOFFICIAL INVENTOR")
parameter("MaterialType") = iProperties.Material
WCrihfield
Try this:
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kPartDocumentObject Then Exit Sub
Dim oPDoc As PartDocument = ThisApplication.ActiveDocument
Dim oUParams As UserParameters = oPDoc.ComponentDefinition.Parameters.UserParameters
Try 'try to find existing parameter
	oUParam = oUParams.Item("MaterialType")
Catch 'that failed, so create it
	oUParam = oUParams.AddByValue("MaterialType", iProperties.Material, UnitsTypeEnum.kTextUnits)
End Try
iProperties.Material = InputListBox("Select a Material", MultiValue.List("MaterialType"), Parameter("MaterialType"), Title := "iProperty Helper", ListName := "UNOFFICIAL INVENTOR")
Parameter("MaterialType") = iProperties.Material
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
ch_giacomo
wow super fast
Thank you very much
It works perfectly
