iMate conflict checking
How to ietrate thru assembly documet and find out any imate results are conflict in the Assembly document?
Solved !
 oAssyDoc = m_inventorApplication.ActiveDocument
        oAssyCompDef = oAssyDoc.ComponentDefinition
        Dim oConstraint As AssemblyConstraint
        Dim oObjectCol As ObjectCollection
        oObjectCol = m_inventorApplication.TransientObjects.CreateObjectCollection
        For Each oConstraint In oAssyCompDef.Constraints
            If oConstraint.HealthStatus = HealthStatusEnum.kInconsistentHealth Then
                oObjectCol.Add(oConstraint)
            End If
        Next
        If oObjectCol.Count <> 0 Then
            MsgBox(oObjectCol.Count & " - Inconsistent Constraints found in this Assembly, Please Correct it before using Bolt Insert")
            Exit Sub
        End If
Burnit87
this works for me
find first part of imate in part occurrence
Dim iMatemate1a As iMateDefinition
For Each iMatemate1a In prtbakXocc.iMateDefinitions
If iMatemate1a.Name = "imate_name" Then
Exit For
End If
Next
find second part of imate in part occurrence
Dim iMatemate1b As iMateDefinition
For Each iMatemate1b In prtbakXocc.iMateDefinitions
If iMatematex1b.Name = "imate_name_2" Then
Exit For
End If
Next
add them together
Dim oiMateResult1 As iMateResult
oiMateResult1 = m_ThisAssembly.ComponentDefinition.iMateResults.AddByTwoiMates(iMatemate1a, iMatemate1b)
BP
