Ilogics rules to modified parts Z offset in Assembly
Hi All,
I Have a bundle of pipes, which I places in a assembly, with only Z offset 25 mm by using Iproperties, Now I want to change all pipes Z offset to 30 mm, I create a costume parameters to change the value but this not effect if I change the parameters.  If there a method or a Ilogic rule to do it? looking forward to hear  from you.
RG
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Please provide sample assembly with pipe to investigate and make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Hi Chandra,
Thanks you for answering.
Actually this are the same pipes you are helping with ilogic earlier this month. This time I want make an ilogic rule in IAM.
Please see attached. this example 12 pipes layer 2 I want to change the Z offset.
RG
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous ,
Try below iLogic code to change position in Z offset.
Sub Main()
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    Dim oDef As AssemblyComponentDefinition
    oDef = oDoc.ComponentDefinition
    Dim occ As ComponentOccurrence
    occ = oDef.Occurrences.Item(2)
    Dim trans As Matrix
    trans = occ.Transformation
    trans.Cell(3, 4) = 3.5 'Z offset in cm
    occ.Transformation = trans
    Call oDoc.Update
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
