iLogic
iLogic
iLogic
Hello guys,
I'm Mark
I'm just new here in this community.
I would like to learn how to create scripting from i-logic and also using macro. I want to understand how generate this scripting form i-logic. I'm really amazed and inspired to this program I hope I could upgrade myself from this learning. Please help me where I could learn this kind of things.
Any recommendations or suggestion.
Thank you in advance
Darkforce_the_ilogic_guy
find a problem at start solve it.  I have made a lot of code this way. an simple code could be add Ben line dimension to all drawing automatic. That is one of the ones i have delevelope..  If you want to Collaboration making somthing just ask
dutt.thakar
@Anonymous
I would advise you to watch KETIV videos on youtube they have a channel, where there are lot of iLogic and Inventor API videos, See below link for your reference
https://www.youtube.com/user/KETIVtechnologies
Apart from that if you check on Autodesk University, there are lot of great classes which will be able to help you to start and also to develop a lot of concepts.
Some of my recommendations.
https://www.autodesk.com/autodesk-university/class/iLogic-Zero-60-90-2018#handout
https://clintbrown.co.uk/category/ilogic/
https://knowledge.autodesk.com/support/inventor-products/getting-started/caas/CloudHelp/cloudhelp/20...
https://beinginventive.typepad.com/being-inventive/2011/08/ilogic-basic-tutorials-on-youtube.html
https://synergiscadblog.com/tag/ilogic/
Try google search on iLogic, Inventor VBA and you will get enormous amount of links and webpages that will definitely help you to kick start.
Hope this will help
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
